Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 135 guests, and 4 robots.
Topics128,275
Posts1,058,572
Members48,492
We are still planning to build our 46 2 ton truck. But, our plans have changed somewhat. Going with V8 gas power & 5 speed manual. C30 or 3500 front suspension to lower the truck.
My question is. Has anyone done this swap or seen it done? do's n don't's?
Servant of the Most High God
1946 Chevy 2ton X Fire Dept Tanker truck from Faith, SD
Do use your tape measure.
Don't be surprised to see the new front suspension is a lot wider than the old.
thanks Grigg.
looks like that's gonna be trouble.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=708681#Post708681
The link above is to a thread about me building a disc brake conversion for my 46. It has taking me a long time to get things done due to running a business and having 5 year old twins. However......I will be completing this before May. Something that I hope to sell!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
thanks Randy.
i'd like to see pics of or do Grigg's swap on a 46 2ton axle.
less fabrications.
The P-30 spindle swap outlined in the sticky thread would then use wheels with a 5.25" center bore and the 46 wheels (and up to 55 or so) would use 4.75" center bore. Bolt pattern is otherwise interchangeable.
One solution if you want to use all the same wheels is have yours bored out to 5.25" or find a set that size and put bushings on the rear hubs to run the larger center bore wheels, or swap to later model rear.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
