1 members (41 chev),
120
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | We are still planning to build our 46 2 ton truck. But, our plans have changed somewhat. Going with V8 gas power & 5 speed manual. C30 or 3500 front suspension to lower the truck.
My question is. Has anyone done this swap or seen it done? do's n don't's?
Servant of the Most High God
1946 Chevy 2ton X Fire Dept Tanker truck from Faith, SD
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Do use your tape measure. Don't be surprised to see the new front suspension is a lot wider than the old. | | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | thanks Grigg.
looks like that's gonna be trouble.
| | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | thanks Randy.
i'd like to see pics of or do Grigg's swap on a 46 2ton axle. less fabrications.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The P-30 spindle swap outlined in the sticky thread would then use wheels with a 5.25" center bore and the 46 wheels (and up to 55 or so) would use 4.75" center bore. Bolt pattern is otherwise interchangeable. One solution if you want to use all the same wheels is have yours bored out to 5.25" or find a set that size and put bushings on the rear hubs to run the larger center bore wheels, or swap to later model rear.
Grigg | | |
