7 members (TexasA&M48Truck, Bill Hanlon, Shade Baby, Nhluvstruck, Brian Moore, Wally / Montana, 1 invisible),
227
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | In a couple of days, I will begin putting the intake and exhaust manifolds back on my 1952, 216 engine after replacing the exhaust pipe studs. The shop manual says to clean cyl head and manifolds flanges, install new gaskets, pilot sleeves and center cap screws with clamps loosely. My question is, should I use some hi temp gasket maker or such to hold the gaskets in place while positioning the manifolds assembly or do they go on dry just as they came from the package? Also as the assembled manifolds are heavy, any other hard earned tips will be appreciated. Thank you. Jim | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | None is needed I did add a few dabs just to hold the gasket in place while assembling working alone.
Torque in sequence to get a good seal, heat box and manifold.
Good luck | | |
