1 members (Jon G), 136 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#924300 03/02/2013 8:42 PM
I was talking with an old-timer in our car club and mentioned I was going to replace the chattering clutch in my '53 w/3-speed. He said loosen the clutch plate, tie off the truck to something solid like a tree, start it, put it in 3rd and let the clutch out. He said let it run like that for a few and it should get rid of the chatter.
I'm just curious, has anyone tried this?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
1 Offline
Go ahead and give it a try. Or start out in 3rd gear a few times. Unless the chatter is being caused by oil on the clutch, this won't usually work. You probably have a pressure plate problem. Either way you will be taking it apart and fixing it right. The warped parts or the oil leak.
The older I get, I only want to work on older rigs.
In my experience soft motor mounts cause more clutch chatter than anything else.
My Blog
magfarm,
I Second Dave,s opinion.
If Your front mount and/or rear mounts are oil soaked out/mush it changes out the Entire driveline alignement/attitude.
Especially when putting power to or torqueing up the engine,ie take off from a stop sign/light
steve sr.
I think the burn will just mess up your flywheel and pressure plate big time.
1951 1 Ton Completed
I agree!
You will most likely end up with heat cracks that can only make things worse.
My Blog
Thanks for the responses guys, perhaps that was a way to keep the farm truck running without taking it down for repair. The truck sat for about 10 years so I suspect a rusty/corroded spot on the fly wheel or pressure plate, it's done it since I first got it running. I will replace and leave the burn-in to the hot rods on the drag strip... grin
Allan
1951 GMC 1/2-ton
I finally got the clutch removed and it appears to be oil on the disc from the transmission side. Is there a seal on the front of the 3-speeds?
Allan
1951 GMC 1/2-ton
