| | | Forums66 Topics128,160 Posts1,057,050 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 23 New Guy | | New Guy Joined: Dec 2005 Posts: 23 | What is a good upgrade option for drum brakes on '52 AD3100 ?
I am looking for under floor master cyl booster options. What is a good donor vehicle? I am keeping drum brakes for now. I am ok with a non power brake option as well. My original master cyl is frozen and I need options.
There is so much knowledge on this forum, I can't seem to narrow a search down. Thanks for anyone willing to share. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most of the specialty supliers have the conversion kits. CPP has a lot of brake upgrade parts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When I rebuilt my 52 3100 I installed a dual master from a 67 C10 chevy truck it's a drum drum ap.no power brakes.Also had to get the adaptor to mount it.Now I'm rebuilding a 53 3/4 ton GMC and I rebuilt the original master and installed it.So I guess both options are fine if you're staying with the drum brakes.
Pete | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I like the CCP kit I used on my '52. I was able to keep the original cross member but it required modification. I also had to custom locate the proportioning valve to frame of truck. I think the CCP kit is a quality kit. But, seems like more than what you want to tackle. | | | | | Joined: Dec 2005 Posts: 23 New Guy | | New Guy Joined: Dec 2005 Posts: 23 | | | | | | Joined: Dec 2005 Posts: 23 New Guy | | New Guy Joined: Dec 2005 Posts: 23 | When I rebuilt my 52 3100 I installed a dual master from a 67 C10 chevy truck it's a drum drum ap.no power brakes.Also had to get the adaptor to mount it.Now I'm rebuilding a 53 3/4 ton GMC and I rebuilt the original master and installed it. Do you have a part number for the kit? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | mr mahoney, PirateJack offer's a great under floor dual master cylinder/booster kit that comes with the brackets and pedal ect. This is a great set up and if you ever decide to go disc your all set up. It is a nice bolt on kit and was fairly priced when I got mine back a year or so ago. My experience was they're nice folks to deal with and may even offer a discount. They are located in Asheville,N.C. which is not far from Tenn depending on where your at. Good luck regardless of what you decide.
