Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Shade Baby, 55shaker, Pre '68 Dave, 1 invisible), 106 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
#924287 03/02/2013 7:58 PM
I am no tune-age expert. I just was thinking.
First start with a 6 to 12 volt transformer.
classic industries transformer
Then an amplifier.
Small Amp
Then a set of speakers.
Classic Parts Speaker
You would just connect to the amp with a male to male ear phone wire.
I appreciate your input.
Lost
1952 Chevy 3/4 ton
1948 Simplex Motorcycle
1930 Ford Model A Coupe
1928 Ford Model A Station Wagon
I believe the amplifier is designed to be fed from an electronic source using a line level signal. I am not sure that you would have control of volume and tone characteristics for each channel separately.
1951 1 Ton Completed
I did a little research on line level signal.
I think you are saying that I can't use the volume control on my I-pod or Kindle to control the volume. That a this amp is designed to take a signal which isn't adjusted and the volume control would be between the amp and speakers instead.
What kind of amp should I look for?
I don't need to make my widows vibrate or the car next to me either. It is just fun to cruise the country roads with a little Nate King Cole, Frank Sinatra, Beach Boys in the back ground.
Lost
1952 Chevy 3/4 ton
Sorry, I didn't mean it wasn't useable. The ad makes some mention of a volume control associated with the amp but there is no reason why you couldn't use the one in your I-pod. If it were me, I would want control of the tone and the split of left and right channels. Can you do that with your I-pod? I don't own one.
The earphone jack is split for ground,, right and left.
My kids like to play with the controls of the stereo in my modern truck (left right, fade balance, bass, treble, and more). I just like it regular sounding.
Thanks for your input.
1952 Chevy 3/4 ton
Then an amplifier.
Small Amp
Lost
The amp is going draw to much amperage for the transformer. It might work at low volume but will start to starve for DC voltage as you crank it up.
Call these guys talk to tech department http://www.casmfg.com/Accessories.htm They sell the transformer/Voltage Booster/Power Inverters.(check link)
The audio input would work from the I-tunes, the problem is not enough DC juice to drive amp.
Check this post for diagrams and links. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=853440#Post853440
If you need more info let me know.
You should check out this link http://www.metroccca.org/tech_articles/tech_08_summer.pdf
It is all about 6 VOLT CONVERTERS for classic or antique automobiles.
Here is a link to one of the converters reviewed. http://www.6to12volt.com/
The above converters can handle more amperage. But cost more.
The converter that you mentioned is really designed to just power radio/CD head units.
Looks like Sony makes an amp that runs on 6 volts link http://www.thesamba.com/vw/classifieds/detail.php?id=796241
After weighting the pros and cons your probably better off buying a 12 volt battery put behind the seat and trickle charge it once in a while.
Its cheaper.
Thanks all for the good info.
I think you are right about the 12volt battery Jorb
1952 Chevy 3/4 ton
Moderated by  truckernix
