| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Gents and ladies, My steering wheel thread on the column shaft are mashed. I started to use a 1/2 - 20 rethreader but it started to eat more of the tip so I stopped. Is there a way to fix this or will I need to get a new shaft?
Bread . | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | I had to rethread mine to that size. The PO had a 14" hot rod steering wheel and he damaged the orginal thread. Go slow, 1/4 turn forward and back. Thread it to get a full Nut.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you file the headed area down first I think the tap will work.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Dave, On curiosity,what is the thread pitch on the shaft? never needed to meas. or chase one on anything I,ve own...lucky I guess. steve sr. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | MtneerMike and Pre'68 Dave, Thanks for the advice and it is competed. I had to cut the tip off, filed the edges down and started the re-threading. Once it grabbed hold, it felt like a was screwing on a nut with a few snags. With a little lube spray, turning 1/4 back and forth, it didn't take any time to finish it up. pic Thanks again, Bread . | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Bread, great outcome on a good thread. Dave, Thank You as usual for Your input,always valued. steve sr. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
