0 members (), 140 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#924224 03/02/2013 3:19 PM
Hi I have a 49 chevy P/U that I am currently restoring. When I bought it all the parts were off of the frame. I had all the parts painted and now I am putting them back on the frame. I am down to the hood. I bought new hood hinges and they came in two pieces. I know how they are attached to the cab and hood. My question what is the best way to mount the hood. Mount the hinges to the hood and then to the cab. or mount the hinges to the cab and then install the hood. I can see it is going to be a task to get it installed. Any help would be appreciated. Any pictures would also help
Thanks Bennie
mount the hinges first, then install the hood onto the hinges.
After mounting the hood to the hinges go to the tech section and look under "body work" there you will find a tip about hood alignment.Good Luck.It may take some time.
Pete
leave the latching mechanism off until you have the hood adjusted,or it may jamb when you close the hood.That will really p*** you off.You don't need to ask how I know.
Leo Offline
Moderator
Moderator
Be sure to get help with getting it in place. Patience is key.
We always set the hood on first with no latch and no hinges to check the fit and gaps. If it fits well then any wrong fit later on is definitely being caused by the hinges being adjusted wrong.
Evan
Thanks for your input I will try this
