1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92408 07/23/2005 9:13 PM | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | I have a 46 3/4 ton that i rewired with a harness from chevs of 40s, I also am installing an hei dist from langdons. i need to replace the ignition switch and im having trouble finding the right one. anyone done this and know of something that will work? thanks, Phil | | |
#92409 07/24/2005 2:21 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | That should be the switch with armored cable that runs through the dash to the coil, no? With the HEI you could use the later truck switch. | | |
#92410 07/25/2005 6:50 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | it's best when installing an HEI in these vehicles to re-run a 10 gauge wire to the coil from the switch. cole hersee for electrical bits any good automotive electrical parts house can help you or contact: http://www.colehersee.com/catalog_top/index.htm
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
