1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#92408 07/23/2005 9:13 PM
I have a 46 3/4 ton that i rewired with a harness from chevs of 40s, I also am installing an hei dist from langdons. i need to replace the ignition switch and im having trouble finding the right one. anyone done this and know of something that will work? thanks, Phil
#92409 07/24/2005 2:21 AM
That should be the switch with armored cable that runs through the dash to the coil, no? With the HEI you could use the later truck switch.
1946 1/2-Ton Chevy
#92410 07/25/2005 6:50 AM
it's best when installing an HEI in these vehicles to re-run a 10 gauge wire to the coil from the switch.
cole hersee for electrical bits any good automotive electrical parts house can help you or contact: http://www.colehersee.com/catalog_top/index.htm
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
