| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | After honing the original slave cylinders and master cylinder rebuilds on my wife's '36 1.5 ton, I had great brakes for a full year. The shoes are all good and there are no leaks. Now after sitting 3 months I take it out for a cold February run and my brake pedal is rock hard and I only the slightest bit of brakes, almost went through my fence. I checked fluid level and it's up. No matter what I do I can not get my brakes back. I know I've got to go back into the system again but has any one been here before? The temp. was in the mid 30's but I don't think I had any water in the system to actually freeze any thing up. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1936only, could it be that your wheel cylinder pistons are frozen (seized) in their bores? | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | It's very possible 3B but they worked exceptionally well not 2 months earlier, I guess I'm in for a tear down this Spring. It felt the same when I installed a '53 Hydro-vac in the '36 when I first built it, I took it out to re-build it but now the same thing. Gotta be the pistons. I think I'll go with new slave cylinders this time. Thanks Bobb. | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Does it change when the weather is warmer? | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | I took it out in December for a Christmas run and it was ok. It was about the same temp. I only honed out the slave cylinders and put in new rubber seals. They looked really good and have no leaks. I'll do the tear down again and check all around, shoes, drums, cylinders again. I kinda like knowing I can stop. I have alot of slop in the E-brake now also, Something to remember after the intial drive, readjust the brakes. Thanks guys, Rick. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My '54 GMC 2 ton is acting a little like that. I've only rebuilt the M/C though,and only have the "hard pedal" and the right rear tnds to heat up and lock after a few miles,even when adjusted all the way loose. Is there a chance you have some water in the system? Speed | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'm just testing right now. I've been having problems with several other forums. :mad: | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Looks fine! WTF??  | | | | | Joined: Nov 2005 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 43 | prob water in the sustem some where agrivated by a loose brake resevior cap or the bottle of brake fluid sitting on the shelf for a while. The fluid attracts water.
Jdude
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Don't forget the hoses, fronts and rears they may look good outside but swell up inside and fluid either won't pass thru to move the cylinder or if it does won't come back quick enough to release them all the way, I've had several lately that have done that. | | |
