4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#923014 02/26/2013 8:46 AM
1 Offline
After honing the original slave cylinders and master cylinder rebuilds on my wife's '36 1.5 ton, I had great brakes for a full year. The shoes are all good and there are no leaks. Now after sitting 3 months I take it out for a cold February run and my brake pedal is rock hard and I only the slightest bit of brakes, almost went through my fence. I checked fluid level and it's up. No matter what I do I can not get my brakes back. I know I've got to go back into the system again but has any one been here before? The temp. was in the mid 30's but I don't think I had any water in the system to actually freeze any thing up.
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
1936only #923020 02/26/2013 9:28 AM
3B Offline
Hy 1936only, could it be that your wheel cylinder pistons are frozen (seized) in their bores?
3B #923026 02/26/2013 10:06 AM
1 Offline
It's very possible 3B but they worked exceptionally well not 2 months earlier, I guess I'm in for a tear down this Spring. It felt the same when I installed a '53 Hydro-vac in the '36 when I first built it, I took it out to re-build it but now the same thing. Gotta be the pistons. I think I'll go with new slave cylinders this time. Thanks Bobb.
"Murtahg"
1936only #923041 02/26/2013 11:00 AM
Does it change when the weather is warmer?
hd4unm #923047 02/26/2013 11:18 AM
1 Offline
I took it out in December for a Christmas run and it was ok. It was about the same temp. I only honed out the slave cylinders and put in new rubber seals. They looked really good and have no leaks. I'll do the tear down again and check all around, shoes, drums, cylinders again. I kinda like knowing I can stop. I have alot of slop in the E-brake now also, Something to remember after the intial drive, readjust the brakes. Thanks guys, Rick.
"Murtahg"
1936only #923215 02/26/2013 10:12 PM
My '54 GMC 2 ton is acting a little like that. I've only rebuilt the M/C though,and only have the "hard pedal" and the right rear tnds to heat up and lock after a few miles,even when adjusted all the way loose.
Is there a chance you have some water in the system?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
1936only #923216 02/26/2013 10:14 PM
I'm just testing right now. I've been having problems with several other forums. :mad:
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
1936only #923217 02/26/2013 10:15 PM
Looks fine! WTF?? headscratch
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
1936only #923473 02/27/2013 9:05 PM
prob water in the sustem some where agrivated by a loose brake resevior cap or the bottle of brake fluid sitting on the shelf for a while. The fluid attracts water.
Jdude
1936only #923904 03/01/2013 10:34 AM
Don't forget the hoses, fronts and rears they may look good outside but swell up inside and fluid either won't pass thru to move the cylinder or if it does won't come back quick enough to release them all the way, I've had several lately that have done that.
