2 members (baldeagle, 3800GUY),
49
Mod | | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | getting ready to fire 216 rebuilt motor primed oil pump set valves .003 more than specs drilled 1/8 hole in thermostat set timing at tdc going to fire this thing without any body other than radiator shroud and radiator plugged oil press and temp on jackstands full roller without body any tips want get chassis complete before installing 51 chev pu body all parts are coupled engine trans rear tahnks for all your help | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tigman 1, good luck with your engines first start. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I would make sure the clutch linkage is connected or put a spring on the clutch fork so the through out bearing isn't flopping around loose. What are you using for a gas tank? An gas can with a hose stuck in it can be dangerous.... | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Nov 2012 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 41 | using a small engine gas tank approx 1 gal with gas line fittings and clamps | | |
