1 members (walter74), 75 guests, and 2 robots.
Topics128,049
Posts1,055,740
#923136 02/26/2013 5:19 PM
Have any of you guys had varying experiences with either fiber or copper faced head gaskets? My truck is out in the garage in ICU. I called advanced auto, they can order either for about 20 bucks. I'm looking for some reccomendations.
The copper gasket is the very old original style. Like a lot of things there are reasons they changed to the newer design. Personally I would never use one of the old copper style gaskets.
1951 1 Ton Completed
Use the newer style gasket instead of the copper.
If it was mine I would use a Best Gasket or a Fel Pro.
Thanks guys, that's basically the same advice I got from baldeagle (Paul). Don, I ended up ordering Fel Pro. I would have assumed the copper gasket was the newer design. I'm just learning as I go. I've been holding the light for others for 20 years. I'm a good light man.
Watching is the best way to learn, you will do fine. Good Luck Don
Holding the light is much easier on the knuckles!
MarcusT53 #924690 03/04/2013 10:59 AM
What do you guys use for thread lube on the head bolts? Below is a video that makes me think this is an important step in getting a evenly and adequately torqued cylinder head.
ARP ultra torque
MarcusT53 #924701 03/04/2013 12:07 PM
motor oil
