| | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | Have any of you guys had varying experiences with either fiber or copper faced head gaskets? My truck is out in the garage in ICU. I called advanced auto, they can order either for about 20 bucks. I'm looking for some reccomendations. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The copper gasket is the very old original style. Like a lot of things there are reasons they changed to the newer design. Personally I would never use one of the old copper style gaskets. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Use the newer style gasket instead of the copper. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If it was mine I would use a Best Gasket or a Fel Pro. | | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | Thanks guys, that's basically the same advice I got from baldeagle (Paul). Don, I ended up ordering Fel Pro. I would have assumed the copper gasket was the newer design. I'm just learning as I go. I've been holding the light for others for 20 years. I'm a good light man. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Watching is the best way to learn, you will do fine. Good Luck Don | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Holding the light is much easier on the knuckles! | | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | What do you guys use for thread lube on the head bolts? Below is a video that makes me think this is an important step in getting a evenly and adequately torqued cylinder head. ARP ultra torque | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | |
