1 members (Goach2), 118 guests, and 4 robots.
Topics128,185
Posts1,057,274
Members48,467
Any one know what color/finish the fresh air heater should be in a '51 3100?
I've seen images of some in blueish gray, some in a light brown and some a pearl beige that matches the interior metal.
For reference, this is the same heater I have - http://image.usedvancouver.com/photos/02/07/25248407_614.jpg
Look under the gasket where the motor attaches to the heater case. You may find the original untouched/unfaded color and sheen. Here is the original color of my '54 FreshAir heater found under the motor gasket. The new Hammerite paint surrounds it.
> CLICK - Original paint under motor gasket
I used Hammerite Bronze rattle can #HAM-41185 on my '54 AirFlow heater. I don't think that it is the right color for your heater. And the "bumps" in the hammertone are too large.
Other Bolters have done excellant jobs refinishing their 1951 heaters. I'm sure that they can give the best match paint brand and color.
- Lonnie
My '54 3104
Thanks, Lonnie! Mine was rebuilt and repainted silver at some point tho so there's no original finish left. ...I bought it that way from baldeagle, my truck actually had a recirculating heater that had an original dark bluish almost black textured finish on it. Decided to go fresh air when the opportunity presented itself.
I was thinking it should be a lightly textured bronze/tan color, slightly darker than the pearl beige dash paint. Doesn't need to be 100% accurate but I'd like it close to original looking.
Here is a typical vintage 49-53 heater your bronze color scheme would be correct.
http://www.flickr.com/photos/advance-design_parts_co/8129343557/in/set-72157631868452754
Here is a NOS GMC for comparison, most of the spray colors I have found are closer to this.
http://www.flickr.com/photos/advance-design_parts_co/8129439492/in/set-72157631868452754
I have a recirculating type so painted mine like this,I have had good luck with the Rustoleum Hammertone. My advice when you find the color is go 3 very light coats to keep the Hammertone effect close to stock.
http://www.flickr.com/photos/advance-design_parts_co/8129058715/in/set-72157631867396207
Thanks Brad! I will probably end up restoring my recirculating heater as well since it was original to my truck. My recirc heater looks similar to yours but the color is much darker and the decal is similar but the raised area is square with rounded corners.
I came across this...
http://www.speedprint.com/deves50/heaterrestore.php?page=1&itemsperpage=All
I'm sure he's a Bolt member but I can't remember his screen name.
Brad is the heater and NOS expert. His word is Gospel to me!
Here are some links that may also help. Note that "twotone" in a link below recommends as Brad does to spray light coats of hammertone paint to avoid getting the big globs like I have on my heater.
> twotone's method of using Hammerite paint
> Photo of twotone's heater
> Deve Krehbiel's heater rebuild
> My heater rebuild
> My completed heater
A search on Stovebolt may give you additional color info.
- Lonnie
My '54 3104
There are several versions of the recirculating heater. The two most common are the early like mine which are up to mid-51. They are slotted to accept an aluminum plate with Chevrolet or GMC see below:
http://www.flickr.com/photos/advance-design_parts_co/8129304429/in/set-72157631868452754
Then there is the later version (this is my complete NOS in box) which is the decal style, mid-51 through 55 Series 1.
http://www.flickr.com/photos/advance-design_parts_co/8129330842/in/set-72157631868452754
There is also a GM Canada version that is a different color/decal style I will
post a picture later when I can find it. There are also some that were used in passenger cars that have a sheet metal enclosure added to direct air flow.
http://www.flickr.com/photos/advance-design_parts_co/8129370166/in/set-72157631868452754
Thanks again Lonnie! Yours came out super nice. Looks like I'll have to order the paint online. No one stocks the spray version in my area.
Brad, my recirculated heater looks like the second one "mid-51 through 55 Series 1" but like I said, the paint is a dark color and it's got a Chev decal on it. I'll snap and post a pic of it this evening.
[edit] Mine looks a lot like this one but the case is tacked rather than held together with screws and I'm almost positive it is a darker color.
Thanks again guys! cool
If the case is tacked it was most liklely rebuilt or modified by a previous owner who may have also done a color change. I have never seen a factory heater assembled that way.
Pretty sure it is original to the truck.
It looks, in construction, just like this NOS one. Tack welded where the vent meets the blower housing.
Rather than this one that is screwed together at the vent and blower.
...otherwise it looks just like this one, same decal, same shape, but darker paint...
I'll post a pic in a couple hours when I get home.
...I'm going from memory here so I could very well be completely wrong... blush grin
Brad - This is the recirculated heater that I originally pulled out of my '51 3100.
http://farm9.staticflickr.com/8089/8493674450_171e80f3bc_b.jpg
http://farm9.staticflickr.com/8091/8493674478_287a922071_b.jpg
My memory failed me on the construction but the color is definitely darker.
And to keep this on topic, here are a couple pics of the fresh air heater I am replacing it with.
http://farm9.staticflickr.com/8088/8493726672_0648bfd6e1_b.jpg
http://farm9.staticflickr.com/8369/8492625865_153faa15d7_b.jpg
On the recirculating that is the color of the Canadian truck heaters I have seen. The dark color is interesting to me I hope someone else can chime in with more information.
The Air-Flow color is surely just PO preference.
http://www.flickr.com/photos/advance-design_parts_co/8129448404/in/set-72157631868452754
Interesting. To my knowledge this truck has been in St. Louis, MO it's entire existence. Rolled off the St.L line in Dec of '51. ...it could have been added later tho I guess.
Did not find the Hammerite locally over the weekend so I went to buy it online ... couldn't bring myself to pay $30 to ship three cans of $7 spray paint. Back to Lowes and bought the Rustoleum Hammered Bronze then headed over to a buddy's house disassembled the heater and blasted the parts.
After blasting, I decided to give powder coating a try in his homemade set up so I coated the blower fan and cooked it. Came out pretty nice if you ask me. smile
http://farm9.staticflickr.com/8108/8507444366_a329e4a436_c.jpg
http://farm9.staticflickr.com/8100/8506333297_854ecccc37_c.jpg
http://farm9.staticflickr.com/8532/8506333351_11f6b9e408_c.jpg
Gotta try powder coating at home sometime. Looks good. Rustoleum should be fine. A lot of colors to choose from. FYI - a local paint store ordered Hammerite for me with no shipping costs.
- Lonnie
My '54 3104
Powder coating is amazingly easy. We are limited to what fits in an electric oven he had leftover from his old house.
The bronze hammered Rustoleum looks pretty close in color to what I've seen of the bronze Hammerite. If I was doing suspension parts or anything exposed to the elements, I'd worry about the difference in durability but for the heater it should work just fine.
I also lightly blasted the end caps of the core and left it to soak in kerosene. I'll shoot it in high temp black after flushing it out.
The Rustoleum Hammered Bronze came out nice! Looks real close to the Hammerite bronze. I think I'll lay it on a little thicker when I finish up the exterior. The trick is to build it up by dusting. It dries quick so waiting between coats leaves it looking sandy and blasting it on too thick gives you that webbed faux textured look.
I've only done the interior of it so these are just teaser shots... I'll update my blog when I get it done.
http://farm9.staticflickr.com/8109/8511239894_2a711b1857_c.jpg
http://farm9.staticflickr.com/8241/8510127929_822e57cc13_c.jpg
Here's Deve's done with Hammerite Rust Cap Bronze for comparison.
http://speedprint.com/deves50/img/deveshowto/heaterrestore/heater19lg.jpg
BLUEMEANIE -
That looks super.
I'm pulling my heater this week to fix a leak. Don't think that I will need to blast off the old paint, but looking at your smooth finish temps me to do so.
- Lonnie
My '54 3104
I started with the interior so I could see how the paint went on. It is not 100% smooth and honestly looks a bit more like orange peel than I care for. However, I noticed that if you shoot it thick without over doing it, let it dry for a minute or two then dust it with a light coat it comes out really good. The light dusting levels out and softens the webbed look the paint is supposed to have and the thick base gives you the texture and gloss.
The heater is painted (looks a bit darker than the ones done with Hammerite Bronze) the emblems are almost completely restored and I picked up new stainless hardware last night. Just waiting on the new 6v motor and I still need to paint the core.
Emblem teasers...
http://farm9.staticflickr.com/8508/8537099812_457ca9a656_c.jpg
http://farm9.staticflickr.com/8530/8510130581_24c3e259f5_c.jpg
I'll post final pics of the color as soon as I get the motor and everything assembled.
I'm just getting ready to start restoring my heater, and it's the greenish blue metallic that BLUEMEANIE posted
here.
The truck is also a '51, built in Oakland and shipped to Alaska. The greenish blue color is pretty pristine under one of the sleeve where the defroster tubes go.
Just another sample. I suppose they may have sourced the heater from Canada, though.
Here's a couple pics. I'll post up what I might find for a matching ratttle can color.
