2 members (NJC, 1 invisible),
109
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | I have just started driving my 1939 truck, and I'd like to see if I could make it steer easier. It's a stock setup right now, but I heard that the 41-46 boxes are better because they're a different design? Is this true and will it let me steer easier? | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | What model 39 do you have?
1939 Chevrolet Stake Truck
| | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | The recirculating ball steering gear introduced in 1941 makes it much easier to steer. I changed mine out in my 1939 GMC 1/2 ton and it makes a world of difference. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1941-46 boxes are a fairly easy swap. Your steering wheel is keyed to the shaft and 41-46 shafts are splined. You will need a matching splined wheel or cut and graft the 39 steering shaft to the 41-46 box. 1/2 ton through 1 1/2 tons use the same box but the 1 1/2 ton box has a longer steering shaft. If you are grafting the shaft the 1 1/2 ton box is a good candidate if it is the easiest for you to find.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | Thanks a lot guys, My truck's a 3/4 ton. I just happen to have a '46 3/4 ton parts truck out back, If I can get that box off and if it's not seized, I'm good to go. | | |
