9 members (VicZ, Ridgeback, RAC1812, Shaffer's1950, Gdads51, artinva, klhansen, Otto Skorzeny, 1 invisible), 122 guests, and 1 robot.
Topics128,077
Posts1,055,928
Members48,430
I have just started driving my 1939 truck, and I'd like to see if I could make it steer easier. It's a stock setup right now, but I heard that the 41-46 boxes are better because they're a different design? Is this true and will it let me steer easier?
What model 39 do you have?
1939 Chevrolet Stake Truck
The recirculating ball steering gear introduced in 1941 makes it much easier to steer. I changed mine out in my 1939 GMC 1/2 ton and it makes a world of difference.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
1941-46 boxes are a fairly easy swap.
Your steering wheel is keyed to the shaft and 41-46 shafts are splined. You will need a matching splined wheel or cut and graft the 39 steering shaft to the 41-46 box.
1/2 ton through 1 1/2 tons use the same box but the 1 1/2 ton box has a longer steering shaft.
If you are grafting the shaft the 1 1/2 ton box is a good candidate if it is the easiest for you to find.
My Blog
Thanks a lot guys, My truck's a 3/4 ton. I just happen to have a '46 3/4 ton parts truck out back, If I can get that box off and if it's not seized, I'm good to go.
