| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | I just now looked at my 235 engine block stamp (55 1st) and it matches the block stamp for the 55 corvette and my head is a 56 number. Im running the 4 speed manual trans.
Is there any difference in the truck blocks and the vette blocks....or passenger blocks? Or is a 235 the same all over for a givven year? Thanks,
Robert Greer 55 1st
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 |
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1955 235 block is the same for trucks, cars, and Corvette. The only difference is the car engine that had a Power Glide transmission was drilled to supply oil to hydraulic lifters.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | Thanks for the info. It was very helpful as always.
Robert Greer 55 1st
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I think if it was a car block with hydralic lifters and a powerglide it also had a fiber camshaft gear not aluminum with solid lifters. Not sure what the corvette had.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You can tell by the engine serial number if the 53-55 235 engine was installed/set-up for a truck, car, or Corvette.
The 235 engines used in 53-55 Corvettes differed from other same-year 235s: - higher lift 261 cam (large truck engine) - mechanical lifters as used in trucks (even though a Powerglide was used on Corvettes - all other Powerglide engines had hydraulic lifters) - aluminum camshaft timing gear (as used in truck 261/235 engines) - of course, different intake/exhaust/carburetors
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | An easy way to tell if a block was set up for truck is that it was cast with bosses for the car side motor mounts but those bosses did not get drilled out for a truck.
Would like to see a complete list of differences in the 235 from it's beginning in '41 to 63. I think that would be quite a long list. The captains bar markings above the starter for one seams inconsistant, have a 53 235 with those bars plus 261s and heard of others with a single bar or no bars at all on some 261s. | | |
