5 members (Denny Graham, Steelonsteel, 66flea, treegrower, Otto Skorzeny), 52 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#922922 02/25/2013 8:09 PM
I understand that the late fifties saginaw 3spds were full syncro if that is the case what kind of numbers should I be looking for to replace the trany in my 58 Apache 235 cu in.I'm getting tired of same old GRIND!!!
Parisenne #922929 02/25/2013 8:50 PM
It was the late '60s when they went full syncro. Not sure about numbers, but you'll want to look for one with a 7 bolt shift plate cover, rather than the 4 bolt found on the 318/319. You may need to shorten the driveshaft, depending on which version you get.
Bill Burmeister
Parisenne #922930 02/25/2013 8:55 PM
don't know from numbers but any GM 3 speed 55-the mid 70's will fit, the Saginaw w/ syncro 1st started in 68 [fine output spline], the earlier [like 58] is a BW trans [coarse spline] ... the Saginaws seem to be getting scarce, you might consider rebuilding yours
Parisenne #923093 02/26/2013 2:01 PM
red58 how come no PM's? A question, are both 3 speeds offered in the TF's from BW?
Parisenne #923103 02/26/2013 2:28 PM
AFAIK, Saginaw didn't start producing 3 speeds until about 62, so I assume all 8 3 speeds Chev used in the 50's were BW
Parisenne #923193 02/26/2013 8:35 PM
Thanks for the help,I plan on going to the big swap meet in Portland so I will keep an eye out for one!!
Parisenne #923249 02/27/2013 5:01 AM
Im just talking about these 2 truck transmissions, I know number 2 is a BW. Also known as a T85. Who made the number 1 transmission?
Number 1 below
http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0702.htm
Number 2 below
http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0735.htm
Parisenne #923273 02/27/2013 7:42 AM
Transmission 1 is a GM corporate transmission also known as a SM318 and with an OD it was known as a SM319. The OD part was BW, but the front part was GM.
Transmission 2 is referred to as a SM 320. It could either be a BW T85 or a BW T89. The T85 has a 9 bolt transmission with the shift levers being in a straight line. The T89 has a 9 bolt cover with the shift levers staggered. Neither had a synchronized 1st. They saw limited use in GM vehicles, but were used a lot by Chrysler, Ford and AMC. Ford used the BW in their Police Interceptor and they stood up will behind the FE390.
The Saginaw resembles the BW, but it is a GM corporate transmission. It was the Saginaw that first offered a synchronized 1st gear.
