| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 27 | I understand that the late fifties saginaw 3spds were full syncro if that is the case what kind of numbers should I be looking for to replace the trany in my 58 Apache 235 cu in.I'm getting tired of same old GRIND!!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It was the late '60s when they went full syncro. Not sure about numbers, but you'll want to look for one with a 7 bolt shift plate cover, rather than the 4 bolt found on the 318/319. You may need to shorten the driveshaft, depending on which version you get.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't know from numbers but any GM 3 speed 55-the mid 70's will fit, the Saginaw w/ syncro 1st started in 68 [fine output spline], the earlier [like 58] is a BW trans [coarse spline] ... the Saginaws seem to be getting scarce, you might consider rebuilding yours
Bill | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | red58 how come no PM's? A question, are both 3 speeds offered in the TF's from BW?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | AFAIK, Saginaw didn't start producing 3 speeds until about 62, so I assume all 8 3 speeds Chev used in the 50's were BW Bill | | | | | Joined: Nov 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 27 | Thanks for the help,I plan on going to the big swap meet in Portland so I will keep an eye out for one!! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Transmission 1 is a GM corporate transmission also known as a SM318 and with an OD it was known as a SM319. The OD part was BW, but the front part was GM.
Transmission 2 is referred to as a SM 320. It could either be a BW T85 or a BW T89. The T85 has a 9 bolt transmission with the shift levers being in a straight line. The T89 has a 9 bolt cover with the shift levers staggered. Neither had a synchronized 1st. They saw limited use in GM vehicles, but were used a lot by Chrysler, Ford and AMC. Ford used the BW in their Police Interceptor and they stood up will behind the FE390.
The Saginaw resembles the BW, but it is a GM corporate transmission. It was the Saginaw that first offered a synchronized 1st gear.
