Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 182 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#92280 07/07/2005 8:24 PM
I have a smallblock with a 'one wire' alternator in my 52 Chevy 3100. The alternator usually does not start charging until I race the engine, then it charges normally and heeps up with the headlights, engine cooling fan, and etc. until I shut off the engine.
Maybe a bad regulator? Anyone have any ideas of how to check out the system?
Thanks for any replies.
Ted
illegitimi non carborundum
This can happen when there is a supposed to be a connection from the alternator to an idiot light and the idiot light is burned out or disconnected. You probably have to rev to around 2000 before it starts charging in this case.
Baldy
Riding in the Passing Lane
I think that is typical of the one wire alt. Thats why they are not recomended.
1972 Chevy c10 Cheyenne Super
52 Ted,
One-wire alternators have the charging characteristics that you describe. Mine kicks in at 750-850 rpm and then charges at all rpm. I have had no problems with it for 7 years.
Tim
You might want to check out madelectrical.com;they have all the info you'll need to make your charging system work properly. I used theor info to wire my trucks alternator in,and it works beautifully.
James
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I agree ... MadElectrical rules the roost when it comes to doing things right, electrically.
Get yourself a Delco 12si alternator (3-wire) ... make sure it has the Delco regulator in it -- that sends less voltage to your battery when it's hot and lengthens the life of everything, including your battery!
I have a bunch of notes about all this at my site, too ... Start here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Wow! Thanks everyone for their responses. I will check out the Mad Electric Site and try their fix. I am happy to learn that my alternator is acting 'normally' but just a pain in the a--.
Ted
Anonymous
Unregistered
Anonymous
Unregistered
Why is it such a pain? I've been running a one wire alternator in my '37 pickup for years. A quick goose of the throttle after starting the engine starts it charging. After that it charges at all rpm's. Not a pain at all compared to changing everything all around again.
