8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck),
87
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Finished the bed side rails on my 49 3100... Pic just added... It's made out of local cedar which is cheap...would love to do Oak but too pricey.
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Drilled the last bolt for the drivers side TPI tubes. http://www.bunchobikes.com/TPI.jpg Removed the intake manifold, removed the valve covers. Valley and rockers look really clean! Someone took care of this motor! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | For me one of the most "fun" jobs in our hobby is to take one item like the heater, vent window, seat, gas tank etc. and tear it down completely and rebuild it. I rebuilt my vent-windows and heater a few years ago and just finished rebuilding the horn.
~Jim
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Finished sheet metal repair on front left cab corner. Front right, windsheild header, and vent tray left to go... Fron left cab corner | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Put the intake, drivers tubes and magnesium valve covers in the soup. | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Pulled the boards out,sanded them down and hopefully will be able to get out tommorrow to buy some marine grade finish to put on. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2013 Posts: 14 New Guy | | New Guy Joined: Feb 2013 Posts: 14 | Not exactly today, but last Saturday...our '58 Apache with a '73 Camaro sub frame:
Hung the control arms, compressed the front springs & put in the pockets, bolted up the spindles, bolted up the new power steering box, idler arm, center link, and inner and outer tie rod ends. (That 1/2 lb. burger & fries afterward never tasted better!) | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Pulled my engine today! Also got the meal assembly off the frame rail. All that is left is a frame and 2 axles! Before I know t il be cleaning and pinting the frame  | | | | | Joined: Dec 2012 Posts: 8 New Guy | | New Guy Joined: Dec 2012 Posts: 8 | Sanded and painted the tail gate. Went for a drive and before I knew it the day was over.
Stump 1969 C-10 With - 305 C.I. Short Wheelbase - Stepside 1986 C-10 With 350 C.I.
| | | | | Joined: Jan 2013 Posts: 26 New Guy | | New Guy Joined: Jan 2013 Posts: 26 | Not able to work on it everyday, but last week I started replacing the frost plugs on the side of the block, and under advise from my buddy decided to pull the tranny to replace the frost plug at the back of the engine. More to come! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Funny how different areas have different names for the same item. We always called them freeze plugs. I guess in Canada it's not a freeze until it hit's 40 below. LOL
This weekend I finally welded the spring tab on the park brake rod fabed a hook and got the return spring working. That has been on my bucket list for a good while.
~Jim
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Drilled and tapped the thermostat housing broken bolt on the intake. Sandblasted the intake. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | PO had welded the end of the crank so the harmonic balancer wouldn't fall off? I was able to pull if off and cleanup the snout, then drilled and tapped it. The woodriff key had seen better days, so replaced it along with the timing cover seal. Re-installed radiator and anitfreeze, good to go. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Found out the 37 will need a new battery,its from wally world and not too impressed with it since day one. | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I finally got the dash back together with all new wiring, bulbs and reconditioned gauges (at home, not sent out). Installed a battery, turned the lights off in the garage and pulled the headlight switch. No head lights yet but I sat in the cab thinking, and smiling, THIS IS COOL.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Very cool indeed! Now Bart, where's the pics?
~Jim
| | | | | Joined: Feb 2013 Posts: 14 New Guy | | New Guy Joined: Feb 2013 Posts: 14 | I painted the backs, edges and hat of my rotors with high-temp VHT header paint, and put on a 3rd coat of red Duplicolor caliper paint on the pair.
Tim | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | new 454 is mounted along with the Clark 5sp OD. Carb on, Manifolds on, Driveline is off to the shop to be shortened. I the process of wiring the whole sucker now | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Took the camper off the deck today (it ruins the mpg) and noticed that the sway bar link on one side is bent like a banana.
Gotta look into that. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Finally finished (it's never really finished) my rebuild of my 52 3100. I'm not using the word "restored" because to many people misuse that term and/or have different opinions as to what really rates the word restored. So let's just stick with rebuilt. I know a lot of you have answered many questions for me over the last 2 plus years and I want to thank you!!! I absolutely wouldn't have gotten this far nearly as quick w/out your help. Thanks a million! Seems like that's how many hours it took!!!! Here's some before after and during pics. Sorry they are not in a good order, but I did good just to learn how to make a link!!!!If this link doesn't work, the one in the trucks for sale section works- Pics
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had some wheels powdercoated several years ago. The cost was $40.00 per wheel. Was your cost anywhere near that?
~Jim
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I picked my '53 3100 up last week, I adjusted the valves yesterday, today took about 100 pictures of it. Plan on documenting the build and using the pictures to help on the reassembly. I have quite a bit of work ahead of me, should be a lot of fun too. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I finally gave up with bench testing my gas gauge, too frustrated. Put the tank back in, put the gauges back in, hooked everything back up and put gas in it. Surprise! The gas gauge reads full! Now for the speedo... | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | "I had some wheels powdercoated several years ago. The cost was $40.00 per wheel. Was your cost anywhere near that?
I think that sounds about right. I paid the company that powdercoated them $70 per wheel because I had them sandblast them first. I didn't want to attempt it, so it was well worth it.
~OldDawg
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Sandblasted the valve covers, tubes, plenum and other items. Glued on the valve cover gaskets. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Because I'm taking my truck on a camping trip next weekend I spent time last night checking things over........ . Pulled all the plugs. Cleaned & regapped them . Checked oil & added 3/4 qt. . Added half gallon of coolant . Checked all the tires & brought them all up to 35 psi . Tightened the fan belt . Stowed the tool box under the seat . Stowed the jumper cables
Hope to have a relaxing, uneventful weekend under the stars by the camp fire!!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | You've got to be kidding me! It's supposed to get up into the 40s here in the next couple days for the first time in months! I live in the wrong part of the country. Camping?! I can't take it. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | They look really nice...I like the color too. I'll got a bit lighter in a cream color I think. I was gonna paint them myself but PC would be better. Mine will be new bare metal but doubt I can get it done for $40 around here. Early wheel charges $70 which I find way too much... | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Woody...glad to find this AND your collection of door art/signs. I'm in the process of developing one that would have been my Uncle's in Salinas, Ca back in the 40's. Markham Cattle Co. One of the pics in your gallery (what a totally cool collection) had a four digit phone and just said "Dial" and then four numbers. Gonna steal that idea. I was able to find his original phone number...four digits..7681...from 1945. Got it from the Monterrey Co. Hist. Soc. Only took them a day to find it. I spent 20 hours scraping 60 years of crud off my frame forward of the firewall. Then I washed it all down with mineral spirits and gave it a good coat of paint. At 61, it pretty much of an ordeal crawling around on your back for the better part of a day but it was rewarding to see it finished. One more thing off the list. PICTURE 1 PICTURE 2 PICTURE 3 | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Figgered I'd try to replace instrument panel bulbs. Dads 50 showed me where the sockets were but I could not feel them. Got a lite and stretched out on the floor to look... There are not any sockets except one for the gauge cluster...all others are MIA. It's always somethin'  | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I am taking the frame to have it sand blasted this week.I hope to have it ready to paint by Saturday. | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Hello All, Finished putting the steering column together. Steering Column Bread . | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Cleaned up the shop and laid out all the intake system that needs to be installed. | | |
