Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (TexasFarmTruck, 1 invisible), 193 guests, and 5 robots.
Topics128,282
Posts1,058,497
Members48,490
#921859 02/21/2013 10:30 PM
Is it possible to replace the fourth gear in a standard four speed, and move 2, 3 and 4 to 1,2,3. This might allow me to build a highway truck without having to do away with the torque tube and original rear end? The four speed needs to be rebuilt anyway.
there's nothing you can do to a 'standard' 4 speed that will change the fact that the highest gear is 1:1, you cannot convert it to an overdrive .... depending on the year, you may be able to just replace the rear gears, keeping the closed drive
ODSS Lawman
ODSS Lawman
There are some options you can do to improve highway speeds and keep a closed driveline. First, based on what year of truck you have, you can install a 3:55 gearset and will improve road manners greatly. Also, you can find and install a Trukstell overdrive unit. This unit installs behind the transmission and is for closed drivelines.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
danorris,
What year/model truck?
Do you have the original rear end?
Additional information:
Patrick's or Mothertrucker's 3.55 Ring & Pinion gears in a 1/2 ton enclosed drive-shaft (torque tube) rear end (if 1937-54)
The Truckstell (Tip-Toe-Matic) overdrive unit (0.73 ratio) requires cutting the torque-tube and enclosed drive-shaft.
If, by "standard" 4-speed, you mean the SM-420, I don't know of any way out.
For a Muncie M-20, there is a kit to change it to have an overdrive top gear. This is an attractive option for the muscle car guys, because it looks bone stock from the outside, and requires no mods to the car at all.
regards,
Leon
Hey Leon, where is that kit avalable??
DG
Denny G
Sandwich, IL
I am aware of patrick's..I'll look up Mothertrucker's. A guy here who worked for GM and then a local transmission shop says there is a Richmond kit that will do it, but your feedback will help me stay out of trouble on this one. The truck is a 51 3100. The 4 speed is an original out of a 48 truck. As far as I know, the rear end is original to the truck.
Dave
If your local guy finds a Richmond ring & pinion kit, let us know.
Patrick's sells an installation kit that includes bearing, bushings, shims, gaskets, and seals. It saves a lot of time/effort.
Thanks, Tim. I'll post again when I get the final story on this.
Dave
