7 members (Charles in CA, LAROKE, Wally / Montana, Cletus1950, 78buckshot, TrknGMC, UtahYork), 137 guests, and 6 robots.
Topics128,107
Posts1,056,221
Members48,436
#922418 02/23/2013 10:58 PM
Hello, everybody. I am in the process of swapping out the 235 in my 1961 Apache, and I've found a small snag that I need advice on. The engine I am putting back into the truck appears to be fine, and doesn't leak a drop of oil... Until I put the bell housing, clutch assy, and transmission on it. I can't figure out why, because the transmission doesn't put any stress on the pilot bearing or the rear main seal- right? When I took the transmission back off, it quit leaking. It doesn't leak much, but a few drips a minute. I guess my main question is, do I need to replace the rear main seal, or go ahead and install the engine and see what happens? My thought is that it might not be making a seal because the engine sat for a few months. What do you guys think? Thanks in advance for your help! The new engine is a 57', not a 61'.
Are you 100% sure it is not transmission fluid leaking out the front of the trans?
My Blog
If you can answer yes to the above question then I'd check for excess crankshaft thrust(end-play).
BC
1960 C60 pasture art
If I had it out I'd do it anyways? Cost about 20 for. A seal and oil pan gasket, would save a headache later
