3 members (panic, baldeagle, 68ironhead), 81 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#922430 02/24/2013 1:56 AM
I just now looked at my 235 engine block stamp (55 1st) and it matches the block stamp for the 55 corvette and my head is a 56 number. Im running the 4 speed manual trans.
Is there any difference in the truck blocks and the vette blocks....or passenger blocks? Or is a 235 the same all over for a givven year?
Robert Greer
55 1st
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
A 1955 235 block is the same for trucks, cars, and Corvette.
The only difference is the car engine that had a Power Glide transmission was drilled to supply oil to hydraulic lifters.
My Blog
Thanks for the info. It was very helpful as always.
Robert Greer
55 1st
I think if it was a car block with hydralic lifters and a powerglide it also had a fiber camshaft gear not aluminum with solid lifters. Not sure what the corvette had.
56 Chevy 3100
You can tell by the engine serial number if the 53-55 235 engine was installed/set-up for a truck, car, or Corvette.
The 235 engines used in 53-55 Corvettes differed from other same-year 235s:
- higher lift 261 cam (large truck engine)
- mechanical lifters as used in trucks (even though a Powerglide was used on Corvettes - all other Powerglide engines had hydraulic lifters)
- aluminum camshaft timing gear (as used in truck 261/235 engines)
- of course, different intake/exhaust/carburetors
An easy way to tell if a block was set up for truck is that it was cast with bosses for the car side motor mounts but those bosses did not get drilled out for a truck.
Would like to see a complete list of differences in the 235 from it's beginning in '41 to 63. I think that would be quite a long list. The captains bar markings above the starter for one seams inconsistant, have a 53 235 with those bars plus 261s and heard of others with a single bar or no bars at all on some 261s.
1946 1/2-Ton Chevy
