2 members (Steelonsteel, Wooley), 141 guests, and 2 robots.
Topics128,167
Posts1,057,020
Members48,458
#922292 02/23/2013 3:33 PM
hi all, just bought a 3/4 ton 1952 chevy. was wondering what the gearing in the rear was. normally i wouldn't care, but i was thinking of building this truck using stock axles with a v8 and overdrive. did a quick search and came up empty. so i'll ask directly. i'd like to go 70mph, if possible.
i'll get some pics up soon.
thanks
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
well i'll have to jack it up, if it's the 4.57:1 i can use it. Are there aftermarket gears for it?(i haven't looked yet)
thanks for the info.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
No aftermarket gears are available for that particular rear at this time. At one time, were was an almost mythical 3.90 gearset that was available, but they have not been made for many years. At this time, the only real solution for higher gearing with the Eaton rear is to find the elusive 4.10 3rd member from the '68-'72 3/4 ton.
Bill Burmeister
yea, i couldn't locate any with my usual suppliers either. thanx all. let ya know on the progress.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
Going with an overdrive trans will drop your RPMs and make your ride way more highway friendly. Another option is do a late model rearend swap. A 14 bolt rear from a dually truck is popular swap. A Dana 60 from a Dodge/Ford van is also a popular swap too.
14 bolt http://s1074.beta.photobucket.com/u...amp;_suid=136167734275303977352668859631
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
What are the three pictures of the ball and tapered bearings for in that album Chris?
DG
Denny G
Sandwich, IL
We used to put 7.50x17 tires on the back of our 3/4 ton and they would run 70 all day long and of course the 7.50x17 carry more load. It looked a little goofy, but it was practical for us. Here is a picture of the last one of them that still saw limited service when I remodeled my house 30 years ago.
http://www.flickr.com/photos/crenwelgeoil/2847834566/in/photostream
Denny- The ball bearings are the oem front wheel bearing. The tapered bearings are the MBS replacements. I got them from Chevs of the 40's and Classic Truck Parts. I don't know if they are still available, since Japan has had an earthquake, tsunami, and nuclear meltdown since I've gotten them.
Ihe MBS are a tighter fit. Some emery clothe to the spindle is necessary. The OEM felt seals won't work with the MBS bearings either. The Timken seal in the picture is a pretty tight fit too. I'm going to eventually order a seal with a slighter larger ID.
Chris
"The Fake Truck"
