9 members (Gdads51, jmoore, King Kielbasa, cmayna, 2-Ton, Danielbolt, JW51, Rusted Nut, 1 invisible),
86
Mod | | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | hi all, just bought a 3/4 ton 1952 chevy. was wondering what the gearing in the rear was. normally i wouldn't care, but i was thinking of building this truck using stock axles with a v8 and overdrive. did a quick search and came up empty. so i'll ask directly. i'd like to go 70mph, if possible. i'll get some pics up soon.
thanks daren | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | well i'll have to jack it up, if it's the 4.57:1 i can use it. Are there aftermarket gears for it?(i haven't looked yet) thanks for the info.
daren | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No aftermarket gears are available for that particular rear at this time. At one time, were was an almost mythical 3.90 gearset that was available, but they have not been made for many years. At this time, the only real solution for higher gearing with the Eaton rear is to find the elusive 4.10 3rd member from the '68-'72 3/4 ton.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | yea, i couldn't locate any with my usual suppliers either. thanx all. let ya know on the progress.
daren
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Going with an overdrive trans will drop your RPMs and make your ride way more highway friendly. Another option is do a late model rearend swap. A 14 bolt rear from a dually truck is popular swap. A Dana 60 from a Dodge/Ford van is also a popular swap too. 14 bolt http://s1074.beta.photobucket.com/u...amp;_suid=136167734275303977352668859631 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What are the three pictures of the ball and tapered bearings for in that album Chris? DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | We used to put 7.50x17 tires on the back of our 3/4 ton and they would run 70 all day long and of course the 7.50x17 carry more load. It looked a little goofy, but it was practical for us. Here is a picture of the last one of them that still saw limited service when I remodeled my house 30 years ago. http://www.flickr.com/photos/crenwelgeoil/2847834566/in/photostream | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Denny- The ball bearings are the oem front wheel bearing. The tapered bearings are the MBS replacements. I got them from Chevs of the 40's and Classic Truck Parts. I don't know if they are still available, since Japan has had an earthquake, tsunami, and nuclear meltdown since I've gotten them.
Ihe MBS are a tighter fit. Some emery clothe to the spindle is necessary. The OEM felt seals won't work with the MBS bearings either. The Timken seal in the picture is a pretty tight fit too. I'm going to eventually order a seal with a slighter larger ID.
Chris | | |
