8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92225 06/27/2005 4:54 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Need help with my gas gauge that does not register. 49 half ton. Guage was rebuilt by a reputable gauge restorer and I also sent the sending unit to him which he tested and says is good. Have one wire to the sending unit. What could be the problem? Any suggestions appreciated. R Wise | | |
#92226 06/27/2005 5:08 PM | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Are you running a six or a twelve volt system? | | |
#92227 06/27/2005 5:17 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | | | |
#92228 06/27/2005 6:07 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If the gauge is good and the sender is good:
- bad lead/wire to the hot side of the gauge (doubtful) - bad lead/wire between the gauge and sender unit - bad ground-contact of the gauge unit to the gauge-cluster-housing (and/or of the gauge-cluster-housing to ground) - you could also have a bad ground at the sender unit but this would not give you the problem you describe (this bad ground connection would result in a gauge always moving from "Empty" to "Full" when power is supplied to the gauge, no matter how much fuel you have)
Tim | | |
#92229 06/27/2005 7:01 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | tclederman: thanks, will check these again. New harness recently installed. The third item you mentioned---grounding of gauge cluster housing. How is this accomplished? rwise | | |
#92230 06/27/2005 8:47 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rwise,
I do not know how the gauge unit is grounded to the gauge housing on the '49.
The housing itself is grounded to the body by the nut/bolt/screw that holds it to the dash (the dash should be grounded). You could check this ground with a continuity test between the housing and any other clean/bare metal on the body/chassis.
If the gauge unit does not need to be grounded, let's hope that someone corrects me.
Tim | | |
#92231 06/27/2005 10:40 PM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Here's what it should be for a 51, but it's probably the same for yours. PS of gas gauge dash unit goes to gas gauge tank unit. DS of gas gauge dash unit goes to ign. switch. Gas tank sending unit should have ground. You can take a wire and connect one end to one of the screw holding down the sending unit and attach the other end to the body. Drill a small hole in the body next the tank where it won't show and tap in a small screw if you have too. Cecil........... | | |
#92232 06/28/2005 2:57 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Grounding, grounding, grounding. If gauge was recently overhauled and the sending unit seems fine then it's the connection between.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#92233 06/28/2005 12:56 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your gauge has two active coils which make it work. With the gas gauge powered up, and the sending unit disconnected, it should register full. Now if you put a ground jumper on the sending unit, it should register empty. The gauge must have a good ground in order to work. In addition, one of the attaching screws of the sending unit should hold a ground wire that normally is terminated on the bottom of the cab. | | |
#92234 06/28/2005 7:49 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Thanks for all of the input. I will resume work on this bugger this weekend. Will let you know. Rwise | | |
