1 members (carbking), 77 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
I have my heater re painted and now I'm looking for some advice on how to polish my name plates and still preserve the blue paint in the recessed areas of my aluminum special heater name plates that go on the front of the heater. Does anyone have a technique that has worked well for them?
I use rubbing compound on a Q-tip for items like that. Go slow and careful!
I cleaned mine up with steel wool and then rubbing compound. I was suprised at how good the paint looked compared to the aluminum before started. I was very carefull. Turned out OK.
If you never tell a lie, you never need to remember what you said.
Brad and Bart - thanks for response. I used the Q-tip cleaning method as I wanted to preserve the blue lettering. I found Testors model paint at Hobby Lobby - Flat Sea Blue is a really good match for the GMC special heater blue letters. Only $1.79. Applied with the tip of a tooth pick.
Nice, show us a picture!
I'd like to see a pic too. I'm working on the aluminum Chev emblem on mine now. So far #000 steel wool has done a decent job brightening the bare areas after which I carefully used a Mr. Clean Magic Eraser clean it up and the rounded end of a screwdriver to press out the dents.
Might still go back into it with some finer steel wool.
BEFORE
http://farm9.staticflickr.com/8369/8492625865_153faa15d7_c.jpg
AFTER
http://farm9.staticflickr.com/8508/8537099812_457ca9a656_c.jpg
i recently was looking for paint to repaint a 99 year old brass steam gage face after final polishing. what i just got last night was this http://www.sharpie.com/enUS/Pages/oil-based-paint-marker.aspx in medium, fine and extra fine. it is an oil based paint. i had to do an immediate test when i got home and was smiling ever since because it will work for what i want to do. so if your satisfied with the colors available dont worry about removing the existing paint especially if the tag is stamped. just fill it in with the extra fine pen and then after it the paint flashes or just about dry go over it lightly with a q-tip with some thinner on it to clean it up. i know they make lacquer pens also but havent found them.
