3 members (TUTS 59, thekid1950, Peggy M), 40 guests, and 8 robots.
Topics128,012
Posts1,055,320
Members48,419
#913594 01/21/2013 10:49 PM
I installed my 4 speed transmission, new u-joint and the rebuilt torque tube in my "52" 1/2 ton. I filled the u-joint housing with gear oil but it never reached the fill port. I put in two 32oz bottles and quit. When I went to fill the transmission it did not take much more. Can I assume the gear oil flows into both the u-joint housing and the tranny. I could not find this answer anywhere in the shop manual. I did install a new okie bushing in the torque tube so fluid should not have leaked into the tube.
If you never tell a lie, you never need to remember what you said.
Bart_Bosco #913602 01/21/2013 11:09 PM
Yes, the gear oil will settle to the same level in the transmission and u-joint housing. Fill to the transmission fill hole height.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0005.htm
Bart_Bosco #913643 01/22/2013 8:06 AM
The rear bearing on the output shaft is not a sealed bearing
Bart. So the two spaces are common to each other. Just make
sure to check the trans fluid level a few times after driving
it a bit. As Tim points out, they will level out eventualy.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Bart_Bosco #913879 01/22/2013 10:10 PM
jorb #913884 01/22/2013 10:20 PM
I did install locking clips on the bolts. Whoever had the truck before me did not which is more then likely why my yoke was in the shape it was in. I had to purchase a new yoke. Actually a pair of clips came with the rebuild kit I purchased from Patricks even though a new u-joint did not so I figured it must be pretty important.
Bart_Bosco #913887 01/22/2013 10:27 PM
At least you caught her be for
she exploded in the Ball housing.
Just in the nick of time.
Bart_Bosco #921720 02/21/2013 4:26 PM
Bart, I realize I am jumping into this a bit late, but where did you find a yoke? I am looking for one for my 56 shortbed stepside and am having a heck of a time locating one.
1956 Apache
1959 Apache
1966 DeVille
Bart_Bosco #922191 02/23/2013 9:11 AM
I think The Filling Station had new yokes available for around $200. I found a used transmission for $75 that had a good yoke with it.
