| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92203 06/24/2005 1:38 AM | | Anonymous Unregistered | | Anonymous Unregistered | Just a quick question, where was the horn button originally on my 53 GMC? Was it in steering wheel? cause that doesn't seem like much of a button. Or was it a button on the dash like my 60+64? Thanks | | |
#92204 06/24/2005 2:05 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It should be in the middle of the steering wheel. | | |
#92205 06/24/2005 2:51 AM | | Anonymous Unregistered | | Anonymous Unregistered | Okay, that was the obvious place. I just wasn't sure because it didnt work, it didn't seem like much of a button. How do you pull off the centre piece? or just pry on it?(I don't really want to break it). Thanks again. | | |
#92206 06/24/2005 3:18 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If I remember correctly, it pries off easily. There is a metal plate underneath with edge retainers. | | |
#92207 06/24/2005 3:25 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yer 60-64s have horn buttons on the dash? :confused: there hasn't been a truck the horn wasn't the center of the steering wheel since ,,,,,,, can't think of a single one!! old Jeeps maybe?
Bill | | |
#92208 06/24/2005 4:40 AM | | Anonymous Unregistered | | Anonymous Unregistered | Okay I will try it tomorrow then. Hmmm, my 60 has a little push button, it also seems that the centre button will not push down. On my 64, their is a abviously not original toggle switch in the dash. Thanks again. I will report back. | | |
#92209 06/24/2005 5:04 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | just because the OEM horn button is broke, don't mean it's not original! not uncommon for the horn wire to short out in the column or elsewhere, and the easy way to deal w/ it on an ol work truck is rip out the wire and replace it w/ a cheapie button from the corner store - the factory shop manual has good info on all the parts of the system, and it's not too hard to make it right
Bill | | |
#92210 06/25/2005 9:46 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | It's worth the effort to diagnose and fix your original horn button. It usually isn't anything too serious. | | |
#92211 06/25/2005 2:54 PM | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Hi, The horn button is indeed in the center of the steering wheel, it has a slot that a screwdriver can be used to pry it off. They come off easily, even if the truck has been in the woods for 20 years... Bill | | |
#92212 06/26/2005 1:26 AM | | Anonymous Unregistered | | Anonymous Unregistered | Thanks for the replies. I pulled off the horn button and it came off easily. After I got that off, nothing was different, so I pulled off the contact plate (??). Then came the steering wheel. The bolt holding the steering wheel on was just finger tight. I then pulled the steering wheel off very (to), easily. I did not see much out of the ordinary (I dont know what ordinary is though). Could it be that my steering wheel wasn't(isn't) far enough down so the buttons aren't touching enough? Also, where can you get some steering wheel crack filler? Thanks so much! | | |
#92213 06/26/2005 3:44 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Steering Wheel Crack Filler is also known as JB Weld. See other thread.
"Happiness equals reality minus expectations" - Tom Magliozzi
