1 members (CATMAN), 158 guests, and 1 robot.
Topics128,162
Posts1,056,935
Members48,458
#921946 02/22/2013 10:37 AM
A pic or two of a little progress on the 3 ton... Bed wood is laid in awating varnish and metal strips being put down. I experimented with an od green on bed rail and frame and think I will go with it on the whole rig. Heres a pic or two...
http://i1259.photobucket.com/albums/ii547/bigredchevy/photo_zps61e630f3.jpg
http://i1259.photobucket.com/albums/ii547/bigredchevy/photo_zps8ef0cb72.jpg
http://i1259.photobucket.com/albums/ii547/bigredchevy/photo_zpsca851517.jpg
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Varnish, I'd find someone changing their oil from a diesel engine and use that on all sides of the wood, it will last longer than varnish.
Thanks, I have heard of that a time or two... Sounds good, and cheap too smile
Troy
1963 Chevy C60
Big Red Chevy
Back when we pulled flatbeds with wood floors, we mopped them with linseed oil on a hot day. I have heard of drain oil but we put wood side boards on the trailers and back hauled food grade grain and the oil stays oily forever. We only mopped the top of the wood because the moisture was to be allowed to escape out the bottom. Our flatbeds now have aluminum with apitong nailing strips which require no sealer.
a water repellent wood preservative would be good too.It looks as if you have used pressure-treated wood.Varnish won't "key"into that very well.
Thanks for suggestions yall. I wasnt sure of the pt wood mixing with all the stuff so i will try and make sure i do this right. I kinda like the oil ideas smile
When rain moves out i hope to get on it.
Troy
1963 Chevy C60
Big Red Chevy
