1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I pulled the ol 235 from my 58 Grumman (GM chassis). Can anyone tell me what modern engine will fit best with minimal modification? The original engine had a downdraft manifold and carb to save space, I guess. A mechanic said he might try a Jeep 4.0. I would appreciate any input on this quandary. Thanks.
1958 Chevy Grumman Olson step van
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I pulled the ol 235 from my 58 Grumman (GM chassis). . . . The original engine had a downdraft manifold and carb to save space, I guess. . . Most likely, you mean "updraft" manifold/carburetor? If you swap the engine out, please post the engine, manifolds, and carburetor in the Swap Meet. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A 250 6 cyl will be the easiest. They are plentiful & run real good. I believe if you use a offset air filter the stock manifold & carb will work. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 |
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Thank you very much-I'll take a look at the 250.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Hi-I found a 250 and a 292. Wondered if 292 was any better? Thanks for any input. Chaz
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Nothing from the 235 will fit on the 250/292. You can use the transmission if you get the later bell housing. later 6 cylinder bell housing is the same as a V-8. Fred
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | In my initial grand plans I sold the '55 235 w/transmission that was in it. Hindsight says I probably should have just kept it. So now I'm going in from scratch -shaft and rear end. I found a good deal on a 292 plus transmission, but I'm thinking maybe I should just keep looking for a 261 or return to a 235. The truck will have a fair ammount of equipment in it, so I'm looking for a bit of extra power. Will a 292 even fit? 261s seem a little rare. Thanks A Lot. Chaz
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The 292 is a great engine with lots of torque. 230/250/292 family engines have similar physical dimensions to a 235/261. The 292 shares many components with the 250 with the exception of the block being taller to account for a longer stroke. Fred
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The motor mounts are different on a 292, they are offset from each other and the 250 mounts are across from each other. If you go the 250 route you can buy a universal crossmember mount for a small block chevy and it will mount easy and also fit the 250 mounts. | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Found a 250-no transmission though. Thinking of putting in an automatic. I heard there is a kit to modify gear shift on the column to auto. Will the 250 clear the radiator ok-I saw both opinions yes & no I will have to run an electric fan. Any other obstacles I might be prepared for? Thanks!
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Why not replace with a good 235 or 261 that are direct replacements? Will save lots of time trying to modify things to fit in your tight engine bay...just a thought. Place a want ad here in the Wanted section and see what pops up... Mike B  | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Does anyone know if a late 261 will mount up to a cast auto powerglide? I think the 261 is a 59 or 60 and powerglide is a 55. The stepvan had a three on the tree, can I alter the shifter for an automatic? Can motor mounts and distrubtor work on the 261 from the 235? Thanks for any help. Chaz
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 261 will bolt to a Power Glide that was behind a 235. Distributor will interchange. Front mount could be a problem if it is a 1960-62 engine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Thanks Guys-Appreciate all the good info! It looks like the orig updraft manifold will fit on the 261-however research shows a Rochester updraft carb on the original. I can't even locate a picture of one let alone purchase one. Just use a Carter? I think if I go the downdraft way I will have to cut/modify the cab to make room. Any ideas welcome. Thanks, Chaz
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I looked at the 261 today & it is a 59-62, looks like a 61. What is the problem with the motor mounts for these years?
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I think I see the problem. The front mounts where the 235 was do not seem to go to the 261. The 261 does have a place for side mounts, are there any types that can be made to fit the 58 chassis. I thought I saw a timing cover that might be able to attach the front mounts, does anyone know about the compatability of these? Thanks.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The front motor mount location changed in 1959 (as you point out). I do not think a timing cover will help but an earlier front plate would have the correct front motor-mounts bolt-holes (or, it would have a lip in the plate that could be drilled for the front motor-mount bolt-holes).
Pre '68 Dave, or someone else, will post corrections and/or better explanations. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There was a post here recently where someone used the 1932-55 first series front mount on a later truck, mounting it off the timing plate. There is the need for some creative mounting to install a 1960-62 engine in a 1958.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Sometimes there is too much info available to process... I like this page for comparing early Chevy 6's. Really does not address 55 or later cars/trucks, but maybe there is something about the motor mounts you can use. URL This page covers 60-66 trucks but may be useful as well. Link Does your motor have a horse-shoe front mount as shown? If none of this helps - then I apologize. Good luck with your truck.
Professional Novice
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | His is most likely mounted like the one in this link.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The first link is a time-honored presentation created by Pre '68 Dave.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Does anyone know of where to find side mounts and adapters to fit on the frame?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Almost all of the aftermarket suppliers like Jim Carters carry crossmembers, but they are designed for V8's and would need to be modified for a 235.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Could a 58 283 fit in this engine compartment? It looks like it has front mounts that would fit.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 283 was an optional engine for 58 [55 up really, and any small block], so likely it'd fit in a step van, but you may need some mods to accommodate the dog house
Bill | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Ok, that's what I thought. I just wanted to make sure before I bought the engine.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Any SBC has the provision for front mounts, but the early small blocks didn't have side mount provisions. This could be a good option. | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Chaz 58, I've seen several of our stepvans modified to accomodate a V8, most commonly the 350. However, any engine mod you make will require redoing your doghouse, as Bill mentioned. Guess that's why they originally used the updraft carb. Mine is a '55, but they are probably the same dimensions. Good luck!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I guess I thought he meant mods to the engine, I really was hoping to leave the house intact. Victor, any other info you have on this subject as far as obstacles in installation would be a great help.
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Sorry Chaz, I don't have any details. Saw one in CA once that had a 350/700R combo in it, but didn't get into any swap details. There's certainly no crime to modifying your doghouse to get the truck you want. Continue to do your research, measure twice, cut once! Good luck!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | So I have the 283, now to switch it to automatic do I need to get a cast powerglide or will an aluminum work as well. I see there is a kit to switch the column shift to auto. How about the rear granny gears? Will the motor produce too much strain on them?
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Will the powerglide attach to the crossmember like the manual did? Is a different drive shaft needed for yoke or for length?
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I have a 1960 261 block and a complete 1965 235. The 261 is missing the rocker arm assembly, water pump, distributor, harmonic balancer and manifold/carb. Can someone tell me what parts will interchange from the 235 to 261? The rocker arm assembly is what I'm concerned with the most. I suupose if I can find another donnor motor, then maybe the same year as the 261 would work best?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 235's were only made up to 1962, so your 1965 engine is most likely a 230. There is nothing from a 230 that fits a 261. Rockers from a 235 will fit a 261. 1959-62 rockers would work best, but 1950-58 would work with minor oil supply conversion.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Does anyone know where I can pickup the rocker arm assembly for a '60 261/235?
| | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | No idea on 235 rockers besides in the swap meet section of this forum or something, but a belated welcome to the forum from another GA member! BTW; that username sucks, lol! ...are you unfortunate enough to have it say that on your drivers license like mine does, too? -the other Chaz from GA.
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I don't know about BTW? You are just down the block from me though, I'm in the sticks in Euharlee.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Hey Dave-if you're out there-what does the minor oil supply conversion consist of if I can't find a 59-62 rocker assembly?
