Brrrr
place holder
8 members (greenie-reddy, G508, Guitplayer, klhansen, Peggy M, dt235sd, Otto Skorzeny, DennisM), 100 guests, and 6 robots.
Topics128,271
Posts1,058,412
Members48,485
#921149 02/19/2013 5:40 PM
Does one of the truck vendors sell a U shaped heater bypass hose for a Chevy 235, or should I just head to NAPA and hope to find one?
The kinked hose is rather unsightly.
Other options? Thanks!
1950 Chevy 3100 short bed
1951 GMC 3/4 ton long bed
there is no "U shaped hose", if the heater wasn't used there were pipe plugs in the holes .... try a plumbing supply store for appropriate size plugs
Thanks Bill. I'll do just that!
Or you can make your own U-bypass with a length of hose and 2 clamps. That's what I had on my last truck.
Professional Novice
Later 261s had a by-pass hose from a port on the water pump (above the heater hose port) to a nipple on the thermostat outlet housing.
BC
1960 C60 pasture art
I have done what Frank50 describes - this is cheaper than buying pipe plugs.
I can't imagine 2 pipe plugs would be enough to ruin the budget wink sounded like what Dickson had was a piece of hose and clamps, and when the hose piece gets hot, after awhile it changes from a U to a V
I reread the post, Bill. I think you are right about the V.
I would have bought brass or stainless plugs.
SS can result in dissimilar metal corrosion and seizing - brass is pretty, for awhile - factory was probably black iron, galvanized works fine, is cheap, looks appropriate
Any good NAPA store will have pic & dimentions of molded heater hose, may have to cut excess off but should be able to come close on the bend.
BC
