| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | I am in the process of installing lever action shocks on the front end of a 1949 truck. I have the shocks mounted to the frame and am looking for some information on how to mount the arm to the axle. Is there a bracked that is attached with the U bolts? I have the brackets that are used to attach the tubular shocks from a 1951. Are the lever action shocks attached with the exact same bracket? A different bracket?
Thanks for any advice. | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | I believe the lever action used a different bracket. I have a pair if your interested for the front. PM me. | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | I'm going to have to agree that I bet it's a different bracket. I don't know for 100% sure but I will take a picture of it after I get off work as mine is still installed on my frame.
Carson | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is an example of what is available from vendors, some pieces are not reproduced for these applications. Cut and paste the long link it will save several levels of searching.
http://www.oldchevytrucks.com/cart/index.asp?cat2=10361&path=1947+%2D+Early+1955+Truck+Parts%2FMechanical%2FSuspension+Parts%2FShock+Absorbers++Lever+Type+Items | | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Thanks to everyone for the responses. I appreciate the help. After looking at Carson's pictures it looks like they are a different bracket. The ones that I have which I believe are for tube shocks have an angle on them whereas the ones for the lever action shocks look like they are flat.
I was asking because when I removed the lever action shocks the bottom bolt was just welded to the axle and there was no bracket. I will look into getting or making a set.
