8 members (Forty9, Joe H, MickeyP, FAST55, 55shaker, 68ironhead, LAROKE, 1 invisible),
63
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i need a little help here, i picked up a 55 235 that hasnt run in 30 years, i took the head off and sent it out to be redone,i wanna replace the cam and lifters, i have it all open now,(timing cover and oil pan off)my question is, is there a special way to pull this cam out?i'm new at this and just need a point in the right direction, im building this motor to replace the 216 in my 46 1/2 ton, any help would really be appreciated | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Remove the lifters. The cam has a retaining plate that is behind the cam gear. The plate is held in with 2 bolts, turn the cam and look thru the hole in the gear for the bolts, remove them and then the cam will pull out. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Its really that simple and btw what I found is that the cam gear is just pressed on. Here is a cool thing to think about too. http://www.stovebolt.com/techtips/timing%20cover%20mod/
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
