9 members (Peggy M, Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, 1 invisible), 69 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
#921703 02/21/2013 3:28 PM
7
7 Offline
I am on the home stretch of a top end re-build on my '55 235 and I have hit a snag. When I took apart the rocker arm assemblies to clean and inspect, I found alot of wear on the rocker arm shafts. I presume that this is because the inner cores of the rocker arms are worn and grooved. So I started thinking about replacing the rocker arms to keep them from tearing up the new shafts. However, I cant find them anywhere...checked NAPA, Carters, Classic Parts, and even made a call to Egge's and the tech there said that they aren't made anymore. So my questions are...what do you do when rebuilding a rocker arm assembly...can the old rocker arms be resurfaced where they ride on the shaft...and has anyone recently found new ones?
737Greg #921717 02/21/2013 4:01 PM
There are places like rockerarms.com that bore them out and bush them.
My Blog
737Greg #921729 02/21/2013 4:57 PM
larrowe and sons did mine, very nice job too...
737Greg #922126 02/22/2013 10:15 PM
1 Offline
I had "rockerarms.com do mine and also make me up a new set of high lift (1.61" Intake) for a set of old 216's I have. I'm happy with everything they have done for me. I traded with them in Torrance, CA and now they are in Anderson, CA. Same good work too.
Normbc9
7
7 Offline
Thanks for the replies! I am now well on my way to a solution...what a great forum! I haven't yet decided which way to go...also found that Chev's of the 40's carries rebuilt sets in stock. I'll update with my decision and the outcome!
