9 members (Gdads51, 55shaker, fonz8261, jay d, TUTS 59, Otto Skorzeny, Jims46, Hotrod Lincoln, 1 invisible),
76
Mod | | | Forums66 Topics128,288 Posts1,058,546 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 21 New Guy | | New Guy Joined: Jan 2013 Posts: 21 | my 55 3100 1st series has a bracket holding a jack attached to the inner right side fender. Did they come with a jack and if so where was the handle kept. I'am also in need of the metal trim around the front windshield. Does anyone still make it? Also need a handle for the jack.
| | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | I believe on the AD trucks(47-55) it was kept in space underneath the bench seat cushion.
tc would know...
-W
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you trust the 55-1st Specifications Manual, the tool box was described as being under the seat (50"x 19"x 6"), and the standard tools were a 2500 lb capacity jack ( screw-handle/crank bottle-style), a jack handle/crank, and a wheel wrench. I wonder where they all are now? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as I pointed out previously Denny, Tims link is actually http://www.1954advance-design.com/Photos/Truck%20Tools/slides/11jack1.htmlthe viglink obfuscation is added by the forum software when you click a link here, need to highlight it and copy/paste to avoid that - which of course can't be done with a "textualized" link as Tim posted .... OTOH, that appears to have nothing to do with your problem accessing Tims site  "I wonder where they all are now?" mostly gone to the smelters, like the ones I've sent off to scrap dealers, shaky ol things that they are  Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | All I know is I LOVE my screw jack. So handy when the rod is chucked in the screw gun. Up down with the flip or a switch. I made a special short bolt to fit as well for up close use. I kinda wish they made a floor jack out of one, at any rate it stay's where you set it unlike a lot of hydraulics. I use it all the time. I may keep it if I sell the truck...
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Still don't understand the "jack attached to the inner right side fender bit." What's with that???? Must have been added by one of the previous owners. I have seen them mounted there, i.e. on the inner skirt but I'm sure it was much later and it might have even been on the competitors trucks.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... and I seem to remember some of my 60's trucks had the jack under the hood
| | | | | Joined: Aug 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 37 | 70's Chevy trucks had them there on the passenger side. I don't remember seeing it on the 60's. | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | some of the 73-87's had the jack in the engine compartment.
Not sure what the model year run was on when they did it tho'. Not really a subject for the 'bolt.
The 60-66 had 'em under the driver side of the bench seat, as far as I know.
-W | | |
