4 members (2-Ton, baldeagle, BC59, 1 invisible),
72
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | where can i get hunter green rattle can automotive strength enamel? i don't need alot, but just enough to do my dash as my paint that i used has faded, and my local walmart, lowes, home depot, etc, don't carry anything green in automotive paint other than bug spit green  any advice is welcomed, Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | enamel is enamel, not sure what "automotive strength enamel" is ..... maybe you have some auto parts stores in reach that carry rattle can enamels? doubt you'll find some specific vintage color tho
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Like Red said... So find some rustoleum hunter green enamal add about 1 oz of clear coat hardener to a sprayable qt (reduced with acetone or lacquer thinner or even mineral spirits) and get happy. You can not add the hardener... but it's what makes it 'automotive'.
| | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | I'm late to this party, but because of curiosity and some knowledge of painting I searched for "rattle can" in this site. Looks like this has sort of issue been visited before. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=856870&page=1 My point is, your fading probably occurred because of inferior products and it is going to do it again. And did you use a sealer over the last finish on the dash? I recommend buying a small touch up gun and learn to use it, it is easy. This way you can buy any paint you want, add anything into it you want (hardeners, flattening base, flexible additives, flakes, etc), get the quality you expect, and save your finger from lots of stress. The little gun does not take that much more effort. That said, I still plan on painting my lower dash with "Hammerite Black" because I want that finish and the stuff is tough. I have plenty of rattle cans on the shelf and in boxes in my shop. But also many hind sight wishes I didn't do that come with it too. Sometimes I got lazy, sometimes went on the cheap, mostly its for very small jobs where absolute color or longevity does not matter. Like CASO says, be happy. I say, get a paint gun. Dave | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | You need a UV protectant added to the paint so it won't fade. Or like the last guy said, quality automotive paint.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | will oil based paint work if hardeners are added? rustoleum sells some that is hunter green in quart cans
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It's just your dash... rustoleum enamal comes in hunter green a cap full of hardener to one of those tiny cans and your there. F the F, and rub your dash out once a year. The older it gets the better it will take a buff. Just put plenty on!
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | will oil based paint work if hardeners are added? rustoleum sells some that is hunter green in quart cans Acrylic Enamel not oil based. Works great. about 1 0z/qt or 1 ml/ 2 oz...
| | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Mater, Ha, oil base is for art paintings and old swing sets. I keep thinking your practicing for the next big job you take on. So have a good time with it, just keep the hardener out of yer' beer. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | thanks you guys, i'm great with the mechanical components of my truck but when it comes to paint, not so much  thanks again, Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | also, i meant to ask this earlier, but can i use appliance enamel for my interior? it seems to hold up well for my headlight bezel which is outside. Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Appliance enamel is suppose to be a tougher finish, but your color choices are slim and rattle can finish is all you get. Avocado, bisque, white. Dash boards take a beating from the sun and people, I'd be trying to make sure it will last. Do your self a favor and get one of these. You'll have it forever if you take care of it, clean it well. http://www.amazon.com/Tool-Force-A-...p;sr=8-1&keywords=spray+gun+touch+up | | |
