5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
First off, I'm running a 70's model small block chevy in my 37. I'm wanting to run the stock mechanical temperature guage, but the v8 has a larger diameter electrical sending unit threaded in the left head. Does anybody know how to overcome this problem? I'm sure someone will know how. Thanks
You can get a brass adapter at the FLAPS. Can't remember the size, so you might take the old sender and the electric sender to the store for sizing.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
One more dumb question. What is the FLAPS? Thanks
Friendly Local Auto Parts Store .... or in the case it's Unfriendly, you might also find what you need at a plumbing supply store wink galvanized reducers work too
What size is the fitting on the 37sender?
Is it pipe or straight?
What size is the fitting on the engine?
I'm not sure right off what threads I'm dealing with. When ever this big blizzard blows by I'll try to get back out to the garage and check.
IF, your 37 sender has 5/8 18NF threads (as my 50 )
and IF, your engine thread is 1/2 pipe
The you could used napa adapter 701-1798
...pic...
I still haven't checked my thread size yet but your pic of that temperature prob looks just like mine. I have a couple concerns though that I need cleared up. First off is: The threaded fitting in that picture has 4 flat sides in it to allow the probe and Bourden tube to pass through the back of the guage.What keeps it from leaking around the fitting? Second issue: My Bourden tube does not appear to be long enough to reach the threaded hole in the DS head (I'm trying to keep the smooth firewall appearance) So I'm wondering if I could thread it into my Edelbrock intake manifold between the carb and the distributor? Any help would be appreciated. Thanks
