| | | Forums66 Topics128,162 Posts1,056,932 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I have a 235 1955 block that i will use as a back up. This motor had a fiber cam and hydralic lifters. The fiber cam broke and took 2 chunks out of the crank. I have another block i can use a crank from. I had it magnafluxed and the pistons in it was already .040. The machine told me that they need to be bored out to .060. I ask if it would hold up to the heat here in Las Vegas. They stated that the 235 block had a lot of meat unlike the newer motors of today. They said it was an ok bore and will not have any cooling problems.
The second machine shop said that would not be good because the walls will be too thin and i will have cooling problems.
I am holding off on doing anything until i get some good input. Then it will be my next winter project if its a good thing to do. I do not want to sleeve the block.
So do i have a boat anchor or consider rebuild. I want to use it for a back up and possibly the primary motor if i decide to do another truck project.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have never seen a problem with .060". It is common to go .080" without any problems, even with performance modification.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | "The fiber cam broke and took 2 chunks out of the crank."
Where did it take chunks out of the crank? Please explain.
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | The fiber gear broke (all the teeth were ground off) causing the camshaft not turn in sink with the crank and 2 of the cam lobes hit the counter weights on the crank. Thats the way i purchased it as a builder block knowing thete was a problem but not sure what was wrong. The owner said he heard a bang and then called a tow truck. As i tore the motor down and getting it ready to have the blocked checked to see if it was rebuildable thats what i found.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Got lots of miles on mine with an .080" overbore. Drill a small hole or wedge an aspirin in the thermostat when you fire it up as these heads like to trap air. Don't go back to shop #2.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | I had my 235 overhauled by a local speed shop. they had to bore .60. I have run it about a year and have never had any problems. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Great thanks guys i think i have my next year winter project lined out.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | There are examples of 235's bored by .125 and they ran OK according to the reports I've seen. It seems extreme to me and overheating would definately be a major consideration. I think it was to illustrate that there was sufficient iron there to do it w/o cutting into the water jacket. | | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | I had my 235 overhauled by a local speed shop. they had to bore .60. I have run it about a year and have never had any problems. Think you ment .060", somewhat differant than .60"! I've run the .060" over 235 in my '60 C10 hard & fast for many years with no issues.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | The 235 in my 55.1 3/4-ton was bored .060 over. Once I fixed the oil pressure problem I had NO problem overheating. That motor ran good and strong. I think Egge still sells .100 over pistons for 235 and 216. Past performance is no guarantee of future results. Your mileage may vary.
Professional Novice
