3 members (Stovebolt48, NJC, baldeagle), 71 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#921169 02/19/2013 6:33 PM
where can i get hunter green rattle can automotive strength enamel? i don't need alot, but just enough to do my dash as my paint that i used has faded, and my local walmart, lowes, home depot, etc, don't carry anything green in automotive paint other than bug spit green eek any advice is welcomed,
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #921177 02/19/2013 6:55 PM
enamel is enamel, not sure what "automotive strength enamel" is ..... maybe you have some auto parts stores in reach that carry rattle can enamels? doubt you'll find some specific vintage color tho
Materman #921242 02/19/2013 11:18 PM
Like Red said... So find some rustoleum hunter green enamal add about 1 oz of clear coat hardener to a sprayable qt (reduced with acetone or lacquer thinner or even mineral spirits) and get happy. You can not add the hardener... but it's what makes it 'automotive'.
Give me ambiguity
or give me something else
Materman #921330 02/20/2013 9:49 AM
I'm late to this party, but because of curiosity and some knowledge of painting I searched for "rattle can" in this site.
Looks like this has sort of issue been visited before.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=856870&page=1
My point is, your fading probably occurred because of inferior products and it is going to do it again. And did you use a sealer over the last finish on the dash? I recommend buying a small touch up gun and learn to use it, it is easy. This way you can buy any paint you want, add anything into it you want (hardeners, flattening base, flexible additives, flakes, etc), get the quality you expect, and save your finger from lots of stress. The little gun does not take that much more effort. That said, I still plan on painting my lower dash with "Hammerite Black" because I want that finish and the stuff is tough.
I have plenty of rattle cans on the shelf and in boxes in my shop. But also many hind sight wishes I didn't do that come with it too. Sometimes I got lazy, sometimes went on the cheap, mostly its for very small jobs where absolute color or longevity does not matter.
Like CASO says, be happy. I say, get a paint gun.
Dave
Materman #921392 02/20/2013 1:14 PM
You need a UV protectant added to the paint so it won't fade. Or like the last guy said, quality automotive paint.
Materman #921449 02/20/2013 5:08 PM
will oil based paint work if hardeners are added? rustoleum sells some that is hunter green in quart cans
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Truckrolet #921454 02/20/2013 5:34 PM
It's just your dash... rustoleum enamal comes in hunter green a cap full of hardener to one of those tiny cans and your there. F the F, and rub your dash out once a year. The older it gets the better it will take a buff. Just put plenty on! yahoo
Give me ambiguity
Materman #921456 02/20/2013 5:38 PM
Acrylic Enamel not oil based. Works great. about 1 0z/qt or 1 ml/ 2 oz...
Give me ambiguity
Materman #921559 02/20/2013 11:12 PM
Mater,
Ha, oil base is for art paintings and old swing sets.
I keep thinking your practicing for the next big job you take on. So have a good time with it, just keep the hardener out of yer' beer.
Materman #921942 02/22/2013 10:28 AM
thanks you guys, i'm great with the mechanical components of my truck but when it comes to paint, not so much blush
thanks again,
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Materman #922410 02/23/2013 10:06 PM
also, i meant to ask this earlier, but can i use appliance enamel for my interior? it seems to hold up well for my headlight bezel which is outside.
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Materman #922469 02/24/2013 9:19 AM
Appliance enamel is suppose to be a tougher finish, but your color choices are slim and rattle can finish is all you get. Avocado, bisque, white. Dash boards take a beating from the sun and people, I'd be trying to make sure it will last.
Do your self a favor and get one of these. You'll have it forever if you take care of it, clean it well.
http://www.amazon.com/Tool-Force-A-...p;sr=8-1&keywords=spray+gun+touch+up
