2 members (Buckeye998, J Lucas),
301
Mod | | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | What can I expect to happen when I run my new engine with old 30 lb gauge? Peg needle? Destroy that gauge? Blow out and make a mess under dash and cab? Should I be pulling gauges and install a 60 lb gauge prior to engine start? Thanks Jerry
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Yes it will peg, I've run one like this for years. Or you can get a 60# GMC gruck ga. fits right in. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Your original 30 lb gauge will likely out last the new reproduction 60lb.
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I have had the stock 30# gauge in my '42 for 15 years and in my COE for 1 year, both have later high pressure 235s. I have had no problems with either. You do peg the gauge when driving but when warmed up you get a reading at idle. You don't know how high the pressure is, but the gauge functions as it should to warn you of TOO LOW pressure.
I doubt the gauges are very accurate anyway. I tested my COE engine with a quality oil pressure gauge hooked up at the block and it pegged at 42#, which I assume is where the pressure relief valve is set and after warming up would idle at 30#. After installing the gauge with it's very long oil line (in the COE it must go forward and up and then back through the firewall) I will get start up readings pegging the gauge, however, hot idle readings are 10# but I don't believe it. As long as it behaves as it usually does I am not going to worry.
Unless your wallet is too fat or you just want something to tinker with, I would leave it alone.
Kent
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | OK Guys, The idea that if its not broke , don't fix it sounds very good to me! Jerry Jerry
