| | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I have a new project. 1953 3100 short bed with the side mount spare. This truck has multiple coats of paint on it. I assume this came from the factory with the sidemount, as the fender has the correct dimple in it. Would the carrier have been painted the same color as the bed or possibly black? Cleon | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You are correct this option first became available in1953. I am unsure on the color though I will look through my advertising materials for some clues. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have read that the factory option was painted body color; however, some people have reported them being painted semi-gloss black). It will be interesting to see what other people post.
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I had an original paint 54 and it was body color.
BTW I have a pair of brackets that mounts to the box for a 53 (only the vertical brackets, not the whole assembly). Let me know if you need them.
Joe
1955 First Series 3100
| | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Only had a couple brackets left on my '54 when I got it. Despite being somewhat rusty, the majority of the paint was still in good shape and was the same mariner blue as the body was. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I'm starting to belive that the correct ,color was the body color. Mine is complete. Thank you for the offer. Cleon | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | However, if it was added at the dealership or installed by the owner it might just have been left in the semi-gloss black e-coat that the bracket was stocked in. In the case of a 3100 side-mount they would have had to paint and replace the fender with a dimpled one but the bracket still might have been left unpainted.
The beds were assembled at the factory complete with the fenders before the finish coat was applied so it just seems reasonable that they would also installed the RPO's before it went to paint.
Bottom line is it could have been body color or black e-coat and still be correct at the time of delivery, just depends on what time frame you want to restore the truck to, that is, factory fresh, time of delivery to the customer or a year after delivery, choice is up to you.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Feb 2011 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 29 | I have an original set of brackets and the mouting face to the bed side is primer black with exposed surfaces painted body color. | | |
