6 members (rfs56trk, wilbur53, dt235sd, J Lucas, JoergK., Bill Hanlon), 84 guests, and 2 robots.
Topics128,205
Posts1,057,427
Members48,471
Page 2 of 2 1 2
I curious what brand pumps you are getting that are going out that quickly on you?
The others certainly have a good suggestion with using an electric pump and wire it so if the oil pressure goes down it won't provide fuel. Hotrod and other can show you how.
Does somebody make a rebuild kit with a diaphram that is ethanol reisitant?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Hotrod and Cletis (via Dads50),
Thanks very much. Might be just the solution I need. Question for me if whether I am getting fuel past the rings that is causing my problem. If the engine runs great, is that likely to be an issue?
I love the idea of a dummy fuel pump, assuming this is the problem to begin with.
Thoughts>
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
Had a 56 with the same problem. The plugs were two steps hotter than factory and burned a hole in one of the pistons. Created a slight miss, hardly noticeable, but gained liquid in the crankcase every time it was run.
Good luck,
Bob
If the dash ain't steel, it ain't real!
H Online: Content
Electric fuel pumps are relatively inexpensive, and the dummy pump approach doesn't make any permanent modifications if you decide to go back to original equipment later on for some reason. It's worth a try.
Its hard to believe you are dumping that much fuel past the rings. A compression check would show low if thats the case. You would also have a bunch of blow-by coming from the draft tube.
Pull the pump apart and look.
Joe
I did have some blow-by coming from the draft tube recently. After a long drive (from Homecoming), I stopped at a gas station and filled up. Another driver saw a puddle under my truck and when I looked, it was under the right side of the engine, near the draft tube. But, by that time, I did not see anything dripping. So, I could not say 100% positive it was my truck, but it seemed logical.
I checked the puddle and it did smell just like the solvent oil I have in my engine. When I got home and parked (out in the gravel near my shed), I put a slab of cardboard underneath to see if anything was leaking. Next morning, there was a small puddle underneath the road draft tube.
Other the other hand, last time SWEET and I checked compression, it seemed to us that we had good compression on all cylinders (100-ish range). Might need to recheck that.
Do you have a procedure for a leak-down test? Would you recommend that?
As for the earlier questions on the fuel pump brands:
2 x Advance Auto (unknown maker)
1 x AutoZone (unknown make)
1 x NAPA (unknown make)
1 x Glass bowl type from Classic Chevy Truck Parts
Will absolutely do the electric fuel pump fix, but would like to examine the possibility that it's related to the rings.
Thanks for the help guys.
Jim
235, 3-speed w/OD
How old is this engine? A fuel washed cylinder will have really clean piston tops. Pull some plugs and look down the holes to see whats in there.
How does the exhaust smell? lean (really hot ), rich ( burn your eyes )?
Has the oil been changed each time the pump went bad? or did it correct it self though evaporation?
How about coolant, is it using any?
I can't figure why fuel will cause a draft tube drip, it should evaporate before getting that far. I understand the high oil level. but what exactly is dripping out? oil or water vapor?
Keep us posted, Joe.
Page 2 of 2 1 2
