| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 16 New Guy | | New Guy Joined: Sep 2008 Posts: 16 | Hi Guys, A neighbor has a 2001 2 1/2 ton with Duramax for sale cheap. I am thinking about putting my '41 cab on the entire 2001 chassis. That way I would have a working truck for my farm. Is this a crazy idea? Is this a tremendous amount of work?
Please let me know what you guys think! | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | The biggest hurdle you would have to over come is the track width of the front axle. You would either have to narrow the axle of the 2001 or widen the fenders of the 41. If you feel like this is do able, then you may also have to stretch the length of the 41's hood or add a dog house to the inside of the cab to cover engine. The width of the radiator is something else that I am sure would have to be addressed. This is such a cool idea that I hate to discourage it. The only way to know for sure is a tape measure and a lot of planning. Anything is possible. Maybe it would be easier to put the 2001's power train into the 41's frame swap out the rear axles and adapt the 2001 spindles and brakes to the 41's front axle beam. | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Hevyhauler makes some valid points, but don't overlook the fact that you'd have to somehow make the duramax run independent of its native truck and associated computers. That to me would as daunting as the mechanical aspects. I'm not saing it can't be done, but you might be better off buying the '01 and using it on the farm, and fixing the '41 and drive it around town. Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I think Scott's idea makes more sense. The steering axle was a lot narrower on the old ones and that creates a big problem. And the steering box wasn't placed in a spot to accommodate a V8. While your idea can be done, I'm afraid your project would get bogged down and you would wind up with two cut up trucks.
| | | | | Joined: Sep 2008 Posts: 16 New Guy | | New Guy Joined: Sep 2008 Posts: 16 | Well guys, I will continue to work on the old truck and just purchase the 2001 for farm work. I just thought it would be cool to have the '41 hauling hay next to the "big" guys. Still might do that for pics when I get the '41 back together, but I won't use her for daily work.
Thanks for the feedback! | | | | | Joined: Feb 2009 Posts: 8 New Guy | | New Guy Joined: Feb 2009 Posts: 8 | Iam wanting to go look at a 41 3/4 ton this weekend and am wanting to put it on a newer frame and run either a cummins engine or a Duramax in it.Want to make it as driver friendly as possible.
Clint Youse Paris,MO
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yousesteers - a 3/4T isn't a "big bolt", it's a pickup, and it'll be a different situation, you need to start a thread in the HiPo Shop
Bill | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Full width fenders are available, got a pair off a school bus, 1.5 ton farm trucks have a very large cutout for the tire, so these won't work. I have seen at least 4 diffferent fenders for '41 to '47 trucks. Keep looking. Good luck.
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Welcome,AlabamaChevy! If you check-out the 1955 "Big-Bolts",in the Gallery,Eric Bureau grafted a '55 2nd-Series L.C.F.,on a late-model Freightliner frame! I would think that his swap would be more complicated than what you're planning to do. I say this,because he was working with considerably less engine-compartment space. He did mention that he shortened the axle by about 14",if I remember correctly. It's been a while since I read Eric's story,but I think that it took him less than a year,to complete his project,working in his spare time! Eric can pull a 16,000# boat and trailer with his rig! He claims 70 M.P.H.,engine turning 2,100 R.P.M.! Says he should achieve between 12-14 M.P.G.! Bureau's truck "runs" a Cummins 6 CT,(8.3L),Eaton/Fuller 9-speed trans. He also changed the rear gears to 3.73. Engine is"mid-range",(250 H.P./1,000 Foot/pounds of torque. Instead of shortening the axle,I'd go with Ed's suggestion,of finding wider fenders. There should be a pair out there somewhere. Patience prevails! Good-Luck,and keep us up-dated,please!
| | | | | Joined: Sep 2008 Posts: 16 New Guy | | New Guy Joined: Sep 2008 Posts: 16 | Thanks everyone! I will keep you all posted with my decision and progress. | | |
