1 members (Otto Skorzeny), 60 guests, and 5 robots.
Topics128,126
Posts1,056,354
Members48,441
#920787 02/18/2013 12:09 PM
I just bought a 46 chevy truck and it has a 235 V6 and it came with a 4 speed saginaw transmission, 355:1 ring and pinion,torque tube conversion kit, 11" front disc brakes, and all installation kits that need to be installed. My original idea was to put a V8, auto transmission and m2 ifs. My question is? If I installed these parts and rebuilt the front end. Other than having to shift and not as much power would there be a big difference in the the ride and do you think that I would have enough power to drive 70 mph on highway and drive in mountain areas and keep up with other cars. Thanks
235 V6?? wassat? the 3.55 rear should get you to 70 and keep up with traffic with any engine .... if you have everything to build a complete useable truck, why start over?
235 V6? Hmmm, the 235 inline is a great engine and actually has more torque (power) than a comparable V8. If your trucks drivable, drive it for a while before doing any major surgery. In short the straight-six/4-spd/3.55 combo should be fine on the interstate and really come alive in the mountains where the V8/auto would just dog.
235 is a straight 6, no american car or truck manufacture made a V6 in the 40's 50's or 60's that I know of. All 6 cylinder engine were inline cylinder designs. Smooth running and good balance are one of the reasons for using that design.
Didn't they use a 216 in the 40's? I don't know.
Didn't GMC truck, and either Buick or Oldsmobile have a V6 engine in the 60's?
1939 Chevrolet Stake Truck
yes, GMC had a V6 in the 60's, but they were 305, 351 and larger, not a 235
Yes the GMC had a V6 305, 351 and a couple bigger.
http://www.6066gmcguy.org/
Some neat info there.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
My mistake. The engine is a inline 6
I'm sure he has a 235 and with 3.55 gears he should do just fine unless he gets into some real mountains, but then the 4 cylinders will be right along with him. If it is indeed a Saginaw, its probably a pretty close ratio between 3 and 4 which is good in mountains. Going to a V8 with an automatic would be a major undertaking that I wouldn't recommend.
Yeah, I remember seeing those old V-6,s in the GMC trucks. The ones with the scalloped valve covers, like a car 348 or 409 V-8.
I thought the V-6 was a real neat engine, would like to have one of those.
I was looking at the pics. posted by Red58. Where are the spark plugs?
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
I didn't post the pics, Jolly did wink
the plugs are inside the V instead of above the hot exhaust manifolds
I had a GMC 478 V6 Magnum in a 1970 Tilt Cab and it was a monster...pass anything but the gas station...lol. If I remember right it was 235 HP, not bad for a 6-cylinder! They take up as much room as a big block Chevy. Would be something different if it was installed in a small truck!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The engine in my 551/2 Panel is a rebuilt 1960 235. Changed the gear ratio in the original rear end (56) with the gear kit. The truck runs fine - cruises along comfortably at 60 (I think, my speedo and odo don't work).
Larry Bear
55.5 Chevy 3100 Panel
Sorry guys forgot about GMC.
