1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92074 06/11/2005 6:48 AM | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | hey i have a c-60 and its been sitting for a very loooong time but it will turn over just not very fast and wont even try to start. but it kills a battery in like 1 minute wuts wrong
wayne | | |
#92075 06/11/2005 8:07 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Many possibilities here. You need to make sure the battery is charged up completely for one. And if the battery is over 3yrs old, I would replace it. They usually don't go much over that anyway. Sounds like you have one or more cells in the battery that have gone bad and you don't have enough amps to get the engine turned over the way it should. This is a start. Cecil...... | | |
#92076 06/11/2005 8:16 AM | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | another thing to check after the battery is the cables and ground, this will make for a hard start too. Make sure the cables are clean at both ends, especially the ground. Try a fresh battery and new points/cap. | | |
#92077 06/11/2005 12:54 PM | Joined: Jun 2005 Posts: 35 Member | | Member Joined: Jun 2005 Posts: 35 | Good advice on the battery issue.
However ... since the truck has been sitting for "a very loooong time", I would think the first question is: Did you just put a battery in it and try it? If so, maybe the problem isn't electrical in nature at all, but mechanical - the engine might be a little tight from just sitting. | | |
