8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC), 82 guests, and 4 robots.
Topics128,064
Posts1,055,860
Members48,428
#92074 06/11/2005 6:48 AM
Junior Member
Junior Member
' Offline
hey i have a c-60 and its been sitting for a very loooong time but it will turn over just not very fast and wont even try to start. but it kills a battery in like 1 minute wuts wrong
wayne
#92075 06/11/2005 8:07 AM
Many possibilities here. You need to make sure the battery is charged up completely for one. And if the battery is over 3yrs old, I would replace it. They usually don't go much over that anyway. Sounds like you have one or more cells in the battery that have gone bad and you don't have enough amps to get the engine turned over the way it should. This is a start. Cecil......
#92076 06/11/2005 8:16 AM
another thing to check after the battery is the cables and ground, this will make for a hard start too. Make sure the cables are clean at both ends, especially the ground. Try a fresh battery and new points/cap.
#92077 06/11/2005 12:54 PM
Good advice on the battery issue.
However ... since the truck has been sitting for "a very loooong time", I would think the first question is: Did you just put a battery in it and try it?
If so, maybe the problem isn't electrical in nature at all, but mechanical - the engine might be a little tight from just sitting.
